Likes Likes:  3
Results 1 to 21 of 21
Thread: 33 Bicycle fender bracket interference
    Feb 2021
    South Bend, IN
    I have a 33 hot rod Gen II that I am getting close to finishing. I just received my Factory Five bicycle fenders and I am having problems with the front fender bracket interfering with the steering rack tie rod end. Steering rack is mounted in the upper holes, suspension is mounted in the upper holes. pics are taken with the car suspended on a lift. When I lower it down the steering tie rod comes in contact with the fender bracket. I cannot see what I am doing wrong, has anyone experienced this problem or know of a solution, this was a lot of money and I am disappointed it does not fit, or embarrassed I am missing something obvious. Fenderbracket interference.JPGIMG_0979.JPG
    Jul 2020
    Spencer, MA
    It appears from your pictures that you have them mounted backwards. Need to see a wider shot showing both ends. The end in the rear should be sloping down. Here's a pic of mine. The front bar should point straight up.
  3. Likes FF33rod liked this post
    Jun 2018
    North Vancouver, BC, Canada
    What Mastertech said.
    You have these instructions, right? https://www.factoryfive.com/wp-conte...KE-FENDERS.pdf
    Gen 1 '33 Hot Rod #1104
    Feb 2021
    South Bend, IN
    Yes , those are the same instructions I am using and I have the bracket installed just like it is shown on Page 3. The bracket leg that is bent down a bit points to the back of the car. I am at a loss as to where I went wrong.
    Jul 2020
    Spencer, MA
    Do you have the tie rod arms on the spindles on the right sides? They should drop down in the back. I just looked at mine and if the arms were on the wrong sides you would have much more clearance, so that's not it. Post a picture with a wider shot like the one I did. I can't put my finger between the the tie rod and the bracket. Set your front frame height at the firewall area to about 5" with the coil overs and recheck. That's about all I can think of at the moment. If you raise the frame height up you should have more clearance.
    Feb 2021
    South Bend, IN
    Fenderbracket1.JPGFenderbracket2.JPGFenderbracket3.JPGFenderbracket4.JPGFenderbracket5.JPGFenderbracket6.JPG
    OK I checked my ride hight and I am 5 1/4" at the firewall. I then checked my alignment thinking Caster setting might make a difference (it didnt). I cannot find the problem. I have a Gen II 33 hot rod with the steering rack on the upper mounting holes and the suspension on the upper mounting holes. I dont know why I have this interference problem.
    Jul 2020
    Spencer, MA
    I'm at a loss on this one. The only difference with mine is that I'm using the lower holes to get that 1" of extra ride height because of the lousy roads here in Mass and speed bumps. Call FFR technical department and leave a message, they'll call you back. Point them to your last post with the pictures. There is a bump steer kit from a supporting vendor that would raise the tie rod ends up on the arms but I don't know who that might be. Look through the suspension and steering section it may be mentioned what vendor has them. I think roadracer put them on his hot rod. You could ask him. Breeze Automotive might have the kit or know where get it.
    My bump steer kit came from Tim at Kootenai Customs.. https://www.facebook.com/kooteniavalleycustoms
    Great kit and beautifully made but obviously will only help if you have bump steer and need to adjust the steering geometry.
  10. #9
    Feb 2021
    South Bend, IN
    Thank you for the input, Still scratching my head on the root cause for the problem. Ill call FFR and see if they can offer anything.
  11. #10
    Feb 2021
    South Bend, IN
    Hey Mastertech, are you using the lower holes on the suspension and the upper holes on the steering rack?
  12. #11
    Senior Member Ltfracing's Avatar
    Aug 2022
    It looks like your bracket’s don’t have nowhere near as much bend in them as these do,not my car,just a picture I found for reference
    33 hot rod,383 sbc tri power setup ,700 r4 transmission,gen1 body gen2 chassis
  13. #12
    Jul 2020
    Spencer, MA
    Quote Originally Posted by easyrider View Post
    No, all lower holes. It specifically says not to do that or visa-versa (bump steer). You have to cut the top of the left rear control arm mount for the rack to clear when using the lower holes so there's no going back without welding the piece back on.
    I was thinking the same thing as Lftracing about the rear arms not being bent down as much. A hydraulic tubing bender may be able to fix that if you can find a shop with one in order to get both sides the same. Would require drilling new holes in the fenders, filling the old ones and refinish.
  14. #13
    Feb 2021
    South Bend, IN
    Fender Bracket Modified.JPGIMG_1147.JPGIMG_1148.JPGJust as an update on my bicycle fender bracket interference problem. FFR Tech suggested I buy the Bump Steer Kit to clear the bracket they supply with the fender kit. I asked if the installation of the bicycle fenders somehow created bump steer and for that reason the bump steer kit was needed but I never got a direct response to that question. In the end I moved forward by having the brackets fabricated that are in the attached pictures. I took this direction based on my belief that Bump Steer would be engineered out of the Gen II 33 Hot Rod if it was assembled in its basic form and not modified in some fashion. So if I get my car on the road and I need to work out a bad bump steer issue then I will pursue installing a bump steer kit and wonder why FFR puts this kit out with an inherent problem, but at this time I have been impressed and pleased with the engineering side of the FFR operation (not the fiberglass side) and I am moving forward with my build with confidence. If anyone else is using the bicycle kit and having a clearance issue with the steering arm let me know, I found a small engineering group that is very professional, willing and genuinely interested to make these pieces.
  15. Likes Just 1 More liked this post
  16. #14
    Jul 2020
    Spencer, MA
    That will work. Nice innovation. Carry on. I agree with your fiberglass assessment. I spent most of the summer getting the nose cone, engine side covers and hood to fit satisfactorily. Not perfect but good enough, and then there are the doors, no matter how I manipulate them on the support structure the front won't conform to the body without having to level things out with some filler. More than I think should be needed.
  17. #15
    Jun 2018
    Good job. I don't believe there were any suspension changes between gen 1 and 2 except the addition of the dual mounting holes. I would expect bump steer characteristics will therefore be the same...
  18. #16
    Feb 2021
    South Bend, IN
    FF33rod, when you say "bump steer characteristics will be the same"...it makes me want to ask, Do you experience much bump steer with your setup?
  19. #17
    Feb 2021
    South Bend, IN
    Mastertech5- I have a solid fiberglass background so I embrace the use of a fiberglass body, I just have a molded part run out of tools that were not maintained. I expect split lines, I also expect the molds to align but my body has a couple places where the surface profile of the molded part are off by a 1/4" from one side of a split line to the other. Throw in some pre-release of the gelcoat prior to lamination and you have a second rate hack job on a really nice chassis. Its all fun in the end, I just keep thinking about how much money I paid for this fun!
    I struggled a bit with my hood, not running side panels, basically chased all the dimensional tolerance to the nose cone and just laminated it to fit. Ill pass along a technique that you may or may not be aware of. I put packing tape (clear packing tape) on my grill, then got my hood close to setup, glassed the space in with long strand glass bondo between the hood and the offset of the aluminum grill. The packing tape acts as a release from the grill and with a little finesse you can get a pretty good reproduction of the grill shape. I sand it and go over it with a good finish bondo and the job is done. Did a similar thing with the nose cone. I am ready for primer and paint, looking for somebody that can spray. Its all fun!
  20. Likes Mastertech5 liked this post
  21. #18
    Feb 2021
    South Bend, IN
    Hey FF33rod, have you experienced much of an issue as it relates to "bump steer"?
  22. #19
    Aug 2022
    The Villages, Fl.
    Easyrider, would you mind sharing who made /modified your fender brackets and the cost ? Thanks, DonS
  23. #20
    Jun 2018
    APologies missed this question, I have the Kootenai bump steer kit so no I don't have any issues. I bought add-on during the build so can't do a before and after comparison.
  24. #21
    Feb 2021
    South Bend, IN
    Hi DonS,
    Sorry for the delay I have not checked the forum in a couple of days.
    Here is the info you requested.
    55 Fab LLC
    Kevin Mentag
    574-261-1099
    [email protected]
    You can reference my son - Patrick Reighter, he is a friend. Small but very good group to work with. Hope this helps.
