Any y'all filled unused holes AKA: mistakes? How or what do you use to fill in unused, unwanted holes? I was thinking JB Weld or some kind of aluminum patch? I'm looking for suggestions here. Thanks
How big are the hole(s)? Regardless, I probably wouldn't use JB Weld. For small holes, a polished (SS) round head screw looks decent and gives the impression it's there for a reason. Larger holes, I'd probably go with a patch. I get it. Everyone likes a nice firewall on the hot rod (or truck) and especially if not installing a hood. But keep in mind, once done, it's relatively busy and much of the view is covered or at least obstructed by the engine and related.
How about panel/hole plugs or sealing grommets? Lots of sources and sizes available.
J1M, ebay has many options from rubber to steel. There are metal polished one's w/clips that just push-in and you're done.
Doug
Dj or Doug or TheLateDude
----- #19 of 25th Anniversary MKIV 9769 -----
Build Link: https://thefactoryfiveforum.com/show...-Slow-Progress
Ordered: Oct 07, 2019 / Production: Dec 28th, 2019 / Shipped: Jan 19th, 2019 First Start: In the future... / Graduation: Even further in the future...
I had a measurement mistake and drilled a couple holes in the wrong place. Thankfully I know a few friends with TIG welders and asked one of them to weld up the holes for me, then ground them smooth.
I threaded the hole and put a screw in it Didn't make a mistake with a bigger hole but would use a plastic or rubber hole plug if needed.... many different brands, some on Amazon even.
Gen 1 '33 Hot Rod #1104
Didn't even think of the metal hole plugs, going to stop by my neighborhood hardware store and see what they have. Thanks guys
