Results 1 to 40 of 45
Thread: Help! Axles are still too short...
    Fun Deprived Member Don's Avatar
    Salt Lake City, UT
    Question Help! Axles are still too short...
    To continue the saga from the other forum...I thought I would post it hear to see if anyone could help.
    http://www.ffcars.com/forums/17-fact...baby-yeah.html
    http://www.ffcars.com/forums/17-fact...lf-shafts.html
    I decided that maybe I did something wrong, or the half shafts I received were faulty. I ordered 2 brand new axle assemblies from Factory Five, Pin Drive Width. I then proceeded to thread my control arm rod ends in 4 threads from where they were, netting about .25" shorter track width per side. This is what I have now...and I am betting that I'll blow them out as well. Look at how far out the bearing is from the housing! What the hell? Am I assembling this wrong? As you can see my alignment is pretty close. At least it was before I threaded the rod ends in further.
    Camber is fine...if anything it has too much.
    Axle is level...
    Rear Rod End...
    Front Rod End...
    Dang bearing is hanging WAYYYY Out! I already blew out the last axles because of this! The red line is roughly where edge of the housing is behind the boot. This cannot be right!!! Is it?
    -Don
    FFR6966 - MK3.1, IRS, AFR 205 headed 408w, depleted bank account, pissed off wife, friends think I'm a hermit, hoping to finish the Cobr@.
    My Build Site PS Footbox Mod .pdf .dwg
    "I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me."
    Salt Lake City, UT
    So, I suspect the pumpkin is not centered in the chassis. I took a measurement and found that the distance the axle has to span is 1/2" longer on the driver's side than on the passenger side. This would explain why I only blew out the driver's side axle when I go-karted it.
    Anyone else experience this inequality with the IRS widths?
    Factory Five? Is this correct or did I receive a defective frame/suspension?
    Last edited by Don; 03-16-2012 at 05:33 PM. Reason: Measure a few more times and found the difference to actually be closer to 1/2" not 5/16".
    -Don
    Salt Lake City, UT
    Guys at Factory Five? Anyone?
    -Don
    Tech Manager, FFR
    Hi Don,
    Just send me those photos & measurements we discussed, and I'll compare to the car we have here. It's got to be either the CV axle itself or the distance between the pumpking and the hub - let's narrow down where the difference is, and we'll figure it out.
    thanks,
    Jason @ FFR
    Port Charlotte, FL
    Don,
    Any chance you have pin drive width axle shafts and non-pin drive width upper/lower rear control arms?
    Henry
    Salt Lake City, UT
    Cobra Dude, I wish it were that easy.
    Jason, like I sent in email, here are some pics and measurements of the axle as installed. The axle assembly as delivered measured 27 1/4" fully compressed.
    The actual length of the axle from the inner housing edge to the outer housing edge where it is beveled down into the hub looks like 17 7/16" to me. This is with the axle at ride height (level).
    -Don
    Master Builder
    Long Island, NY
    Any resolution to the problem yet ?
    Kenny
    Salt Lake City, UT
    From what I have gathered over here...see thread, I would say that the frame mounts for the diff are shifted to the PS of the car and extending the DS axle enough to cause the failure. Right now I am waiting to see what FFR can do for me. I am hoping that they will come through and help me get some longer axles made up.
    http://www.ffcars.com/forums/17-fact...too-short.html
    -Don
    Master Builder
    Long Island, NY
    Thanks Don , and good luck .
    Kenny
    Salt Lake City, UT
    Jason,
    Any word on what to do about this? All I need are longer axles for the problem to go away!
    -Don
    Salt Lake City, UT
    Pretty quiet around here...I still cannot drive my car the way it is...Jason, Dave, anybody?
    -Don
    What the heck, is FFR sitting on this? The car isn't driveable and spring is here. Come on FFR!!!
    Salt Lake City, UT
    The only way I am going to be driving any time soon is if I throw more of my own money at it. In the end, I think that is what I'll be doing regardless of what FFR determines. There is just no way on earth that this can be solved given these suspension parts, which all came from FFR. I will have to go off the reservation to get this fixed anyway. Now it just comes down to who will pay for it.
    So far I have spent $247 purchasing new axles from FFR and I am poised to spend another $250 to send one off to DriveshaftShop to be taken apart and assembled with a custom length 16" halfshaft. Total...~$500. Frustration level...7.5.
    -Don
    I'm going to move this to the Tech forum. Brian Z checks there frequently during the day.
    Mark Twain
    Tech Support, FFR Brian Z's Avatar
    Wareham MA
    I did already see this thread. I will have to check with Jason and see what he has found out about this situation.
    Checking into it...
    Brian Zakrzewski
    FFR Tech & Sales
    O'Fallon, MO
    Don, take apart the axle and post some pictures, PLEASE.
    Salt Lake City, UT
    Don, can you pull the axle out and have a look at how its assembled?
    Ok Rich, I will see about taking apart the brand new ones from FFR so you can see. Sorry for making you wait. I just did not want to adulterate them if I was going to be sending them back to FFR. The older pin drive half shafts I recieved were like this...the c clip was obliterated and the bearing was pushed back and stuck on the axle. I had to pull it off with a gear puller. The new ones, I have not looked at yet.
    My old standard width half shafts had a built in stop on the inside so there was no need for a clip behind the bearing, and FFR did not have an inside clip because of this...IMHO that was a much better design. Even Kirkham Motorsports uses this design element:
    Not sure what my new pin drive half shafts look like as one is shipped off to Driveshaft Shop and the other is heading back to FFR for a refund.
    -Don
    Salt Lake City, UT
    Quote Originally Posted by Brian Z View Post
    Checking into it...
    I could definitely use some more help here. Thanks.
    -Don
    Salt Lake City, UT
    Hey, Brian or Jason...any updates?
    -Don
    Salt Lake City, UT
    Updates? Frustration level is rising from 7.5 to 8.0.
    So far, this is where I am at:
    • Verified via my rear alignment that my brake disks are perfectly centered to the 4" rails.
    • Verified that my axles, being fully installed into the differential and fully seated into the hubs, are ~.500" different in length. Being longer in the driver side.
    • Verified that the driveline flange of the differential is mounted ~.688" off center toward the passenger side.
    • Verified that the differential cover tab is mounted in the frame ~.907" toward the passenger side.
    • I had given FFR the benefit of the doubt and spent $247 of my own money to replace my first set of axles with a new set from FFR.
    • I would like to send the one off to DriveshaftShop to have a longer half shaft made and assembled. The other I would like to return to FFR for a refund (it is still sealed in a bag), but FFR has not responded to that request for a refund, nor offered to cover the total cost of the DriveshaftShop to make me a longer axle (~$250 shipped)
    • I am dying to get this problem resolved.
    -Don
    Salt Lake City, UT
    Friendly bump to let FFR know I am still here.
    -Don
    O'Fallon, MO
    "the older pin drive half shafts I recieved were like this...the c clip was obliterated and the bearing was pushed back and stuck on the axle. I had to pull it off with a gear puller"
    If the bearing was all the way back, stuck on the axle, then of course the bearing would be too short, and slip out of the housing.
    Salt Lake City, UT
    Yeah, I realize that. Now consider the 'new' axle that I just installed, with the bearing still sticking way out of the housing, would you drive it like that? I know that I blew out the last axle and it looked just like this as well...hmm, what are the odds that I may get lucky and it will be fine?
    What was the definition again for 'Insanity', oh yeah...doing the same thing over and over, each time expecting a different result.
    -Don
    Senior Member Gopher's Avatar
    McHenry, Illinois
    Don I feel your pain .The drive shaft that came with the kit was about 2 inch to short .No problem called FF said no problem will send you the one that's about 1 1/2 longer just send yours back. Of course that's on my dime. Week goes by new one shows up that one is 1 1/2 too long you can't even install it .Now I find out there's three drive shaft lengths .I made the mistake and assumed it was the length that was listed on inventory sheet and did not check before I shipped it back . So now I'm just going to take this on and have it shortened to the length I want.
    Anniversary Special,Dart Aluminum 427, AFR 225 outlaw heads,Howard Cams,Hillborn stack injection,Liberty Gears prepedTKO600, Five Link, ISIS Wiring,8.98 @151 with no power adders Photo album HTTP://photobucket.com/anniversary-car
    Tech Manager, FFR
    Hi Gopher - it sounds like you're talking about a driveshaft - can you confirm? If you're referring to a CV axle, please drop me an email at [email protected] - I'd like to learn more about your configuration.
    Don - just emailed you a bunch of photos and measurements from our Pin Drive IRS Mk3. I think they should be helpful.
    thanks,
    Jason @ FFR
    Salt Lake City, UT
    Thanks Jason. I'll review and take matching measurements on my car.
    -Don
    McHenry, Illinois
    Quote Originally Posted by Jason Lavigne View Post
    thanks,
    Jason @ FFR
    Yes Jason its a drive shaft .
    Salt Lake City, UT
    Well, I have some good measurements in. Jason at FFR was nice enough to measure Dave Smith's car for me so that we an compare it to my car. Here are the results...
    Dave's car, DS 25.25” rear diff mount tab to inner disk face
    Dave's car, PS 24” rear diff mount tab to inner disk face
    Dave's car, DS 18.125" inner axle housing to spindle
    Dave's car, PS 18" inner axle housing to spindle
    My car, DS 25.125” rear diff mount tab to inner disk face
    My car, PS 23.3125” rear diff mount tab to inner disk face
    Sorry didn't take pics of the inner axle housing to spindle measurements, but I did measure them at full droop just like Jason did and noted the measurements below.
    FWIW, my car IS aligned fairly well. I aligned it to the 4" tube using the string method and took great care to make sure it was spot on.
    So after looking at my car again...and back at Jason's measurements I think we have pretty good confirmation that my differential is mounted ~.25 too far to the PS making the span the axle has to cover ~.25" shorter on the PS and ~.25 longer on the DS. This equals the ~.5" total difference in the DS and PS axle length requirements. Please see the following analysis...note that Jason's measurements on the rear diff mount tab to inner disk face are slightly larger, likely due to his measurements taken at full droop slightly on an angle, while mine were taken level at ride height.
    __________________________________________________ __________________________________________________ _________
    My car (measurements taken at ride height, same as the photos I sent earlier. I measured again at full droop, but the difference between the two is the same.)
    Difference…1.8125”, divided by 2 equals .906” offset to PS.
    Dave’s car (measurements taken at full droop)
    Difference…1.25”, divided by 2 equals .625” offset to PS.
    Now this shows that .906" minus .625" equals .281". This is roughly the .25" that I have been noting for a few weeks that my diff was toward the PS. Let's also look at the other measurements that we took with regard to how far the axle reaches on each side...
    My car (measurements taken at full droop, I took these today)
    DS 18.375" inner axle housing to spindle
    PS 17.6875" inner axle housing to spindle
    Difference .6875”, divided by 2 equals .343” offset to PS.
    Difference .125”, divided by 2 equals .0625” offset to PS.
    Now this shows that .343" minus .0625" equals .281". This is roughly the .25" that I have been noting for a few weeks that my diff was toward the PS.
    I don't know what more to say, other than our specs are matching up very nicely to tell the same old story. The problem is that my control arms are all the way in on the DS and I cannot adjust it anymore to help the situation.
    Don
    -Don
    Salt Lake City, UT
    bump
    -Don
    Salt Lake City, UT
    bump...Whew! Almost forgot to let FFR know I am still here.
    -Don
    Salt Lake City, UT
    bump
    -Don
    Don, I think you should call FFR and ask for Dave Smith. It's unacceptable that his staff is basically ignoring you and I'm sure he'd like to know what the heck is going on.
    Mark Twain
    Salt Lake City, UT
    Quote Originally Posted by oldguy668 View Post
    I emailed Dave for the first time 2 days ago. No response yet. I'll try his cell next.
    -Don
    President, Factory Five Racing Dave Smith's Avatar
    Barrington, RI
    Don - I can promise you that no one is ignoring you. We met this morning and I asked Jim to investigate this fully. I'm sure he'll be contacting you.
    Dave Smith, FFR 001
    President
    Factory Five Racing
    Salt Lake City, UT
    Thanks Dave. Jason has been helping out, no doubt.
    -Don
    Here's the old guy with his foot in his mouth again. I should not have used the word "ignore". There were 37 alternative words or phrases that would have done the trick. The problem is I should not be on the forum right after speaking to a particularly irritating client. The dog is lucky she didn't walk by just then or I'd be getting arrested for animal cruelty.
    Mark Twain
    Salt Lake City, UT
    This one's for you Rich! I pulled the boot back. The first 2 pics are at full droop...the last pic is at ride height.
    DS at full droop with the rear LCA rod end showing only 1 thread past the jam nut. Imagine what it would have looked like on my first go kart ride when I had 5 threads showing. No wonder my first axle exploded! Now imagine that my diff was centered properly, this would only put the diff ~.25" closer. I am not the type of guy to say the sky is falling, but this is dangerous enough that I would HIGHLY suggest the pin drive guys pull their boots back to see how far their bearings are hanging out. This could result in a tragic failure at speed.
    This pic is the same with the wheel raised to ride height.
    -Don
    Wow. Thats scary. Gotta go look at the one I have here.
    Salt Lake City, UT
    Yep, exploded on 12-30-2011 during my first go kart ride. Been trying to convince FFR that this is a problem ever since. All brand new parts...complete kit.
    -Don
    Salt Lake City, UT
    Well, I am officially into my 4th month of dealing with this issue. Hoping to get back on the road soon.
    -Don
