I've got about 4k on my 818s. My clutch pedal seems a bit soft. I want to bleed the system. Any tricks to accessing the clutch reservoir? Should have installed a remote during the build. Do I need to remove the windshield?
You can trim the windshield surround to make a door. I can't find pictures of mine and I'm out of town, but basically you can cut a rectangular hole to reach through. If you do it neatly you can use the piece you cut out as a door to cover the hole.
Thanks, I thought about cutting the surround, but I always get a little nervous when I start cutting. When you get home, maybe you can send some pics
No problem, car is put away for the winter
