Thanks Thanks:  12
Likes Likes:  47
Page 3 of 3 FirstFirst 123
Results 81 to 115 of 115
Thread: Terry's LS MK4 Build
    Feb 2022
    Flower Mound, TX
    Quote Originally Posted by BRRT View Post
    Hey Terry, your accessory drive setup looks great!
    When you had your engine in, did you check your driveshaft? FFR provided driveshaft #16038 with my order. Due to it being so short, I only had about 1 3/8" of engagement with the transmission output shaft. Most of the yoke was hanging out.
    I contacted FFR and sent some pics. They have driveshaft #60175 on the way to me. My engine is still in for test fitting, so I will see how it lines up once it arrives.
    Thanks Jeff, I'll definitely measure before I drop it back in. Appreciate the heads up.
    Feb 2022
    Flower Mound, TX
    Looks good. How do intend to plumb between the lower radiator and thermostat housing?
    It shouldn't be too difficult since the radiator inlet and outlet are both on the passenger side, but those are famous last words.
    Feb 2022
    Flower Mound, TX
    Bellhousing Alignment
    Not much new to report, other than I removed the drivetrain assembly and installed the clutch and Tilton 6000 hydraulic throwout bearing. Prior to that I checked the alignment of the bellhousing and was pleased to find that I don't need any adjustments (i.e. offset dowels).
    In case it helps anyone else, I used an alignment method prescribed by Silver Sport Transmissions. It's very simple and straightforward. They describe it in this video:
    Using this method, I ended up with a final number of 0.0025, which is within the 0.005 tolerance required by Tremec. I believe the smallest available offset dowel 0.007, which wouldn't help here.
  4. Thanks zarnold thanked for this post
    Likes BRRT liked this post
  5. #84
    Feb 2022
    Flower Mound, TX
    Drivetrain install
    Pardon the absurdly large photos... I must have forgotten to resize correctly.
    Pretty good weekend, got the final drivetrain install done. I'm sure other LS builders will agree that this setup sits in there very nicely, but no surprise given the dimensions are similar to the SBF. The crank pulley sits about an inch (maybe a hair less) above the cross member, and that's with the FFR LS mounts and no spacers. Very happy about that. As can been seen in the photos, I rotated the fuel rail 180 degrees and converted the quick-connect to AN.
    The trimmed Quicktime bellhousing sits about dead even with the bottom of the 4" tubes. Crappy photo, but you get the idea:
    I was able to get the transmission aligned within spec to the rear end with three 1/4" spacers from Forte:
    And finally, as I think I noted previously, the shifter landed in a perfect location without having to cut any of the chassis.
  6. Likes Mike.Bray, Jim Frahm liked this post
  7. #85
    Feb 2022
    Flower Mound, TX
    Again, it's been a while since my last update.
    My primary focus now is getting everything in place required to start the engine. I've got the wiring harness and PCM installed, along with the primary power wiring. As you might imagine, there are no lack of fancy billet PCM mounts out there, but I chose to go with an $20 GM unit from eBay that's made of some sort of plastic or poly material. Apparently using a conductive mount can lead to ground looping issues.
    The fans are all wired and tested. At low temp, both Spal fans move at half-speed and they barely make any noise. At high temp, both fans run at full speed and I think they could suck a small child into the radiator. Still pretty quiet though. The relay box is installed on the 3/4" tube in the engine bay. The fan harness is specifically for dual fans and the LS platform/PCM.
  8. #86
    Feb 2022
    Flower Mound, TX
    The fuel lines are all in place and pressure tested with my compressor and soapy water. Good old-school leak test. Of course I'll double check when the system is pressurized with fuel. The regulator sits just inside the passenger side rear wheel well and is very accessible.
  9. #87
    Feb 2022
    Flower Mound, TX
    One thing I'll need to figure out is the connection to the lower port on the radiator. The tow loop is right there and doesn't provide much room, so I think I'll need to trim or remove it completely (maybe replace with a threaded tow hook like you'd see on many modern vehicles). Other than that, the routing is pretty straightforward.
  10. #88
    Feb 2022
    Flower Mound, TX
    Wow, going on a couple months since my last update. Glad blogging isn't my day job.
    The engine bay is filling up, with a lot of time spent on thinking through things like hose routing, tank placement intake design, etc. And then sourcing the parts. It's all a lot of fun, but definitely time consuming.
    In the most recent previous post, I mentioned how the lower radiator might be a challenge because well, this is an LS and I also have a custom radiator. I had to make a hose out of three molded hoses. Good thing the local NAPA guys are really patient didn't mind me sitting there with the catalog and asking them to retrieve certain hoses. In the end, I bought about twelve hoses and kept five to complete the upper and lower hoses. I made sure to keep the part numbers for future reference. I had to insert a 1.25" to 1.5" transition in the upper hose.
    I went with Canton expansion and overflow tanks. I found out Canton operates an eBay store where they sell their blemished items for about 50% off in many cases.
    Expansion/surge tank:
    Overflow tank (the bracket's will be removed and coated):
    The system is designed around this diagram (thanks to fellow builder Bruce for pointing me to it). I had seen it on the internet before, but not the variation without the heater.
  11. Likes Mike.Bray liked this post
  12. #89
    Feb 2022
    Flower Mound, TX
    The intake took some consideration. I thought about keeping the filter in the engine bay like most people do, but GM is pretty specific about spacing requirements for the MAF sensor. Granted, plenty of people have deviated from those requirements with fine results. But I'd like to keep this in-spec as much as possible, and I'd also like to see if I can get cooler air into the engine ("cooler" is an amusing word when you live in Texas). It turns out that it's been done before with a MKIV... see this post in It's Bruce's build.
    I essentially copied Bruce's setup (what's the imitation/flattery saying?) after a bunch of PM's exchanged...
    This is just temporary hardware... no need for 1.5" bolts.
    The filter will end up looking like this:
  13. Thanks Its Bruce thanked for this post
  14. #90
    Feb 2022
    Flower Mound, TX
    As other LS builders have noted, the factory dipstick is not an easy fit mostly because of the engine mounts. After jacking around with it for a while, I finally decided to install a Lokar unit, which worked perfectly.
    A small bend to the Lokar bracket, along with a spacer and cap screw, and it's all good:
    Fairly clean routing to the dipstick port:
  15. #91
    Senior Member BRRT's Avatar
    Sep 2020
    Quote Originally Posted by OB6 View Post
    That starter/motor mount/motor mount adapter/header/spark plug area sure gets crowded when it comes time to install a dipstick tube. I did something real similar after trying to bend and modify 2 GM dipstick tubes.
    Yours looks real clean!
    Roadster delivered 8/27/23
    Chevrolet Performance LS3
    Feb 2022
    Flower Mound, TX
    Thanks Jeff - yes it's a tight area. I ruined one GM dipstick before deciding I needed to go a different route. I couldn't get a smooth enough bend that fit without the dipstick getting stuck.
  17. #93
    Senior Member Its Bruce's Avatar
    Houston TX
    Looking great!
  18. #94
    Feb 2022
    Flower Mound, TX
    A quick panel for the relays and such...
  19. #95
    Feb 2022
    Flower Mound, TX
    I got the air filter installed. This should work well. The rest of the intake is at the coater getting treated with cermet along with the headers.
  20. #96
    Feb 2022
    Flower Mound, TX
    Time for another series of procrastinated build posts. Overall, I'm getting prepared for first start. Things that need to be done before that include the following:
    • Fill tank and test fuel system pressure
    • Prime and fill engine with oil; will be using Driven BR30
    • Install new master cylinders and bleed the hydraulics... more on that below.
    • Temporarily install oil pressure and water temp gauges
    • Maybe pressurize the cooling system prior to first start, or just let 'er rip and see what happens. System is filled with DexCool.
    • Adjust/set the Tilton hydraulic throwout bearing. I guess this isn't really necessary for first start, but it would be nice to have it done
    • Install side pipes
    The engine bay is 99% done.
    I decided to have the headers ceramic metallic coated... essentially the same as JetHot.
    Also had the intake pipes coated the same way. The heat reduction won't provide a material benefit in this application (compared to the headers), but they look nice and match.
    Power steering lines are installed. I kept it simple and just routed them over the X member. Lee Power Steering was a great source for everything.
    I finished the gas pedal using an extra pedal pad that I ordered from Mike Forte a while back. I think it came out pretty well. The nice thing is how adjustable it is. I can move it up, down, and side to side if needed. We'll see how the current position works out and go from there.
  21. #97
    Feb 2022
    Flower Mound, TX
    Leaking Wilwood MC
    I mentioned above how I needed to install new master cylinders. I've always had this feeling that it will be "when" and not "if" one of the Wilwood MC's fails... based on nothing more than what I've read here and other forums (not necessary FFR related). I even contemplated proactively replacing all of them before I get the aluminum buttoned up, but I didn't make it a priority. Until this morning.
    I started to bench bleed the clutch MC and wouldn't you know... it started leaking. I didn't get upset or annoyed... I just grabbed my wrenches, removed all three MC's and headed down to Summit Racing for new Tiltons. Sometimes it's better to just find a different solution and move on. I'm not taking it up with FFR or Wilwood... it's just not worth my time, and I have zero interest in installing a new Wilwood or rebuilding it.
  22. #98
    Feb 2022
    Flower Mound, TX
    Almost ready for first start. Just tested the fuel system -- no leaks, fires, or explosions, and 58 lbs at the rail.
    Just need to install the side pipes.
  23. #99
    Feb 2022
    Flower Mound, TX
    First start!
    Big day today with the first start of the LS3. No leaks or funny noises. All systems were operating perfectly according to the OBD2 scanner. Fans came on as they were supposed to. It really helped to have a couple friends there to check things along the way.
    https://www.youtube.com/shorts/1GEP8Us2VCA
    https://www.youtube.com/shorts/5xKEotfrAAs
    Those are just temporary wheels and tires. I'll put rubber on the Halibrands sometime in the next few months. These work fine for now, and no worries about dinging them up.
  24. Likes Mike.Bray liked this post
  25. #100
    Sep 2022
    Nice Job Terry! Congratulations on this milestone
    Craig C
  26. Thanks OB6 thanked for this post
  27. #101
    Senior Member JimStone's Avatar
    Nov 2022
    Niles, MI
    Great job! I've been watching your LS build and taking some pointers, although mine is for a coupe.
    Ordered: 2/14/2024
    Received: 5/24/2024
  28. Thanks OB6 thanked for this post
  29. #102
    Senior Member Jim Frahm's Avatar
    Jun 2017
    Cheney, WA
    Congrats! That sounds just like it should!!!!!
    I'm currently fitting doors, hood, and trunk. Once that's complete I'll be ready to get it licensed.
  30. #103
    Congrats Terry! I've been quietly following along because I may be venturing down a similar path soon. Thanks for the documentation!
    Feb 2022
    Flower Mound, TX
    Quote Originally Posted by cc2Arider View Post
    Craig C
    Quote Originally Posted by JimStone View Post
    Thanks guys!
    Quote Originally Posted by Jim Frahm View Post
    Cool, thanks Jim. BTW, your clutch pedal stop is gold. Good luck with the body fitment... I'm not looking forward to that.
    Glad it helps Jeff. I should probably call you soon to get in your queue.
  32. #105
    Houston TX
    Sounds great . I enjoy the oh so common "whoa, it actually started. Oh yah, I should be checking the oil pressure..."
  33. Likes OB6 liked this post
  34. #106
    Feb 2022
    Flower Mound, TX
    Yeah I was expecting it to crank a little longer than it did, so it took me by surprise when it came to life. It almost looked like the ignition switch shocked me. Lol
  35. #107
    Feb 2022
    Flower Mound, TX
    Dash
    The dash is almost done. The four mounting brackets behind the dash are installed and the screws are countersunk to keep them from showing under the leather and the closed cell backing (probably 1/16 or 1/8, no more). Thanks to others before me for the idea (and especially) to John Ibele for his assistance via PM.
    This process wasn't without drama. I originally attached a 0.40 backing layer to help with rigidity. Unfortunately I used 3M Super 77 which I've had great results with in the past. Unfortunately I think this Texas heat isn't conducive to proper curing, and furthermore I read that it only has heat resistance up to 150 degrees -- which could spell trouble when the dash inevitably sits in, again, the Texas heat and sun. I should have done more research before using 77. Luckily I was able to remove the backing layer without any damage to the dash. I chose to move forward without it, and only use small pieces of backing in certain places as needed (for example, between the dash and mounting brackets). I'll use panel adhesive for that.
    I used a variation of the comp layout, sitting in position to make sure I could see everything well. Because of this, I decided not to place any gauges to the left of the steering wheel hub. Additionally I decided to place the clock above the grab handle... a decision that I knew would be a "love it" or "hate it" thing. I like it a lot -- IMO it gives some balance and something extra to the dash. I'm sure many will disagree.
    The only other items I'll add to the face of the dash are the e-brake button (probably to the left of the steering hub), a couple billet push-button switches for high-beams and interior lights, and the check-engine light. I want to keep it as clean as possible. The hazard switch is built into i.e.427's turn signal switch. The switches for headlights, ignition, and wipers will all go under the dash in the panels I built.
  36. #108
    Sep 2022
    Looks good Terry! I like that you are making your own special customizations
    What's the part number for your grab handle?
    Craig C
  37. #109
    Dublin, OH
    I like it.
    I too wanted something on the PS dash to break up the blank space, especially since I wasn't having a glove box there.
    I think Shelby himself put the speedo on the PS dash to piss off race officials who required a speedo in a race car.30B1875D-81E2-42B0-B2A7-12C3394E6915.jpg
  38. #110
    Feb 2022
    Flower Mound, TX
    Craig C
    Thanks Craig. It's a 12" stainless handrail from West Marine, model # 12868733.
  39. #111
    Feb 2022
    Flower Mound, TX
    I like it.
    Thanks - I really like your dash... the layout and the color. Yes, that would seem to fit Shelby's personality.
  40. #112
    Feb 2022
    Flower Mound, TX
    First Go-Kart
    Today was a fun day. I got the first go-kart ride in, and everything went well.
    https://www.youtube.com/shorts/DqVVPk_36so
    https://www.youtube.com/shorts/7T60COm1-YQ
    A few observations:
    • The clutch and hydraulics are silky smooth, with no chatter, funny noises or other weird things. Phew.
    • I'm very glad I went with power steering.
    • Pedal placement seems to be really good. I wasn't hunting for any pedal or snagging my sneakers on anything. Maybe I'll need to make adjustments after the carpet is in, but for now it's all good.
    • I need to tighten up the exhaust, as I was getting some popping on decel. Easy fix, and no surprise because I know I didn't fully tighten the collector.
    • One tiny coolant leak at the expansion tank. I'll give it another heat cycle or two because the Gates Powergrip clamp might tighten further. If not, it's a minor fix.
    • I've haven't done an alignment yet, and I could tell.
    • The tires are marginal at best, but I only expected to use them as rollers. I bought the wheels from a guy in town, and the tires came off our daughter's Mazda when I replaced her tires. They're fine for now, but I'll look forward to getting tires for the 18" Halibrands.
    • It's been a while since I've been in a car with this kind of power-to-weight ratio. Good lord.
  41. Likes Mike.Bray, F500guy, Its Bruce liked this post
  42. #113
    Feb 2022
    Flower Mound, TX
    Just a few dash updates I forgot to post.
    I was able to get the bracket for the handrail completed, although it needs to be painted or powder-coated. I made it with 1/8" x 1" flat steel, 1" angle, and some 5/16 and 1/4-20 fasteners I had. I'll use proper locking hardware at final install. That said, it's rock solid as it sits, and should make the handrail very useful.
    I decided to place the ignition, wiper, and headlight switches under the dash on the center panel. This should help keep the dash layout cleaner.
  43. #114
    May 2023
    Frisco, TX
    If you want to powder coat that, and any other small parts, you’re welcome to come over one of these coming weekends. Between sanding, degreasing, spraying, and baking, it would only take about 45 minutes. I’ve gotten pretty decent at powder coating things over the last several months.
    MKIV Complete Kit # 207585
    Ordered 8/19/2023. Completion date 11/11/23. Delivery date 11/27/23
    Build Thread: http://https://thefactoryfiveforum.c...577#post535577
  44. #115
    Senior Member JMD's Avatar
    Mar 2024
    Kansas City, MO
    Congrats on the go carting! I just got there a couple weeks ago...sure is gratifying to hear and feel it do it's thing for the first time, isn't it? Hard to believe the mechanical part is pretty much over...it's all about the body from here on out. (Hopefully.)
    Build thread: https://thefactoryfiveforum.com/show...809#post556809
    MKIV received 5/15/24
    Blueprint 302 tuned by Mike Forte, TKX midshift, IRS, PS, Wilwoods
