Thanks Thanks:  2
Likes Likes:  2
Results 1 to 11 of 11
Thread: Shifter Cables - Teleflex discontinued?
    Jul 2020
    Hi all,
    There have been suggestions of using Teleflex Xtreme Control cables (CCX43007) as a replacement for the factory cables when run straight back.
    However I am having troubles sourcing these cables. Whenever I place an order, the store cancels it and states the product is discontinued.
    Is there a replacement/supersession, or a cable that would work just as well? Somewhere that will ship these cables to Canada?
    Syracuse, NY
    Quote Originally Posted by Neeraj Ahluwalia View Post
    Hi all,
    I can't help with the sourcing issue your having but I can confirm that the Teleflex Xtreme cables are excellent! Keep trying.
    MK3.1 Roadster completed 2011
  3. Likes Neeraj Ahluwalia liked this post
    Mar 2020
    Braintree MA
    Hi all,
    Teleflex was bought by Dometic a few years back. They still offer the cables though using pretty much the same model numbering system. You can try going to a marine store. That’s how I know about it
  5. Thanks Neeraj Ahluwalia thanked for this post
  6. #4
    May 2020
    I have a 96” cable from the VCP K Tuned kit I am not using.
  7. #5
    Dec 2019
    I bought cables from Custom Control Cables in Houma, LA and am happy with them.
    Ed
  8. #6
    Nov 2021
    Chicagoland
    Mine are from Midwest Control Products...
  9. Thanks Neeraj Ahluwalia thanked for this post
  10. #7
    Mar 2014
    Hingham, MA
    Quote Originally Posted by driveslikejehu View Post
    Same. Work well.
  11. #8
    Jul 2020
    Thanks all for the help. It seems that Teleflex was indeed bought by Dometic, however they no longer offer the 4300 series (1/4"-28 fittings).
    Scouring the marine forums I have seen a lot of suggestions for both UFlex Mach Zero and CableCraft Blue Max cables (and some others). However these are all only available in #10-32.
    Would it be a bad idea to downsize to #10 fittings? It seems they have a push load capacity of around 80lbs.
  12. #9
    Nov 2021
    Chicagoland
    Midwest Control has 1/4-28... in many lengths and the right end configuration
  13. Likes Neeraj Ahluwalia liked this post
  14. #10
    Jul 2020
    How flexible are they? They do seem to ship to Canada. Want to try to minimize slop
  15. #11
    Dec 2019
    A 1/4" push/pull cable will be fairly substantial, somewhat flexible yes but you want to route it with as few and gentle bends as possible. The reason the FF5 stock setup is sloppy is that they have you running the cables forward with about 270 degrees of total bend by the time it gets to the transmission. My setup with an MR2 shifter and the cables running aft has only about 15 or 20 degrees of bend total and is very smooth and positive.
    As far as any particular brand of cable goes, what you are looking for is something with a low friction liner - teflon or something like it. It won't require lube and will last a long long time.
    Ed
