Just curious if anyone has gone this route? Would the racks from more recent mustangs (2011 and on) Bolt into a Mk4 without significant modification?
I did a Electric Power steering, after market not OEM. You can see the route I took in my build thread. OEM would be nice, I thought about my 2020 Miata EPAS would be cool, but I did not do the work to see if it would fit.
I have electric power steering on my Speedstar. I purchased a Rugged brand unit from Demon Power Sports. It is the same motor as the one sold by FFR for less than 1/2 the cost. It works well in the limited driving I have done so far. It also has provisions to accept a speed input to make the assist speed sensitive but so far I haven't seen a need for it.
The 2011 up rack will not work.
Check out my build thread. I installed an epowersteering.com unit, seemed to fit well. Uses the FFR manual rack. Does require welding. I have not wired it up yet, but the installation was straight forward.
Rebostar
520 Speedworks offers electric PS, and they're a supporting vendor. Greg is also a great guy and easy to work with.
Rick
Here's my review of the Speedworks 520 or Epowersteering kit for the Cobra.
Overall happy with the system. A speed sensitive system would be nicer if you track your car.
https://thefactoryfiveforum.com/show...ghlight=sjdave
PS - BE AWARE - The pins in the connector from the under-dash boost control have there way of working themselves out of the connector housing. I added some hot melt adhesive to glue them into the connector body.
Mk 3.1 #6616 Complete Kit, July 2008 Start, Gromm Racing 347, TKO 500, IRS, Carmine Red / Wimbleton White
Mk 3.1 #6756 Complete Kit, May 2016 kit completion, Smeding Alum. 427 Stack Injection, TKO600, Custom Silver/Blue (SOLD)
