Thanks Thanks:  10
Likes Likes:  178
Page 6 of 6 FirstFirst ... 456
Results 201 to 215 of 215
Thread: # 1115 resurrection
  1. #201
    Oct 2023
    Quote Originally Posted by Just 1 More View Post
    Yeah, not sure how the polished firewall is going to hold up. the new tires are definitely gravel kickers. My 383 came with the build but I had it re-built at NYE's racing engines. 401hp 437tq. What's your Skip White HP numbers?
    The 383 I’m looking at is advertised at 503 hp, 484 torque. I’ll know the actual when it arrives with the Dyno sheet. From speaking to Skip, at Skip White performance, it will be very street friendly. He’s used that combo often.
  2. Likes Just 1 More liked this post
  3. #202
    Sep 2022
    Huntington, IN
  4. Likes JimLev liked this post
  5. #203
    Placitas, NM
    I bought those same Hagan Fatties, nice mirrors.
  6. Likes Just 1 More liked this post
  7. #204
    Apr 2023
    Schott Accelerators
    Nitto 555 G2's
    18x9 275/40-18
    20x11 315/35-20
    Attachment 196614Attachment 196615Attachment 196616
    I'm interested in buying the McQueen bike fenders like you. Can't wait to see them on your car with those size tires and wheels that you have choosen.
  8. #205
    Sep 2022
    Huntington, IN
    Quote Originally Posted by cvacca View Post
    Not going to be so easy, I need to do some serious modification to the fronts to get the coverage I need. Tires are bigger than the fenders
  9. #206
    Apr 2023
    275's in the front are wide, but look mean! How do you think the 315's in the rear will fit under the fenders, or do you think they will need to be modified also?
  10. #207
    Sep 2022
    Huntington, IN
    The 315's will barely fit, might stick out a little but that's ok with me.
  11. #208
    Sep 2022
    Huntington, IN
  12. Likes Ltfracing, TxMike64 liked this post
  13. #209
    Sep 2022
    Huntington, IN
    Had a little self inflicted set back. I drilled a hole in my fuel tank. So, great excuse to get a Boyd's tank. Ordered one this morning. Pulled the tank out last night.
  14. Likes Ltfracing liked this post
  15. #210
    Sep 2022
    Huntington, IN
    Finished up the McQueen rear fenders last night. Didn't see how many fasteners to use so I did 7 using 1/4-20 rivnuts (deep reach for fiberglass) and stainless button heads on each one. Started 2" from each end and spaced 8.5" apart was the perfect layout.
  16. Likes Ltfracing liked this post
  17. #211
    Apr 2023
    Good job! Will be nice to see when it's back on the ground how the spacing of those big 315's look with the edge of the fenders.
  18. #212
    Sep 2022
    Huntington, IN
    While the tank is out, I took the opportunity to add a coating of the Boom Mat spray. This is my first time using this product and so far, I really like it. Nice thick coating that seems to do what it's intended to do. Did a little on the inner doors also.
  19. Likes TxMike64 liked this post
  20. #213
    Kingsland, TX
    Those fenders look great!
  21. Thanks Just 1 More thanked for this post
  22. #214
    Sep 2022
    Huntington, IN
    Installed the 3pt belts and removed the 4pt harness'. I think I got them installed correctly, didn't have any instructions.
  23. Likes TxMike64, 33fromSD, Ltfracing liked this post
  24. #215
    Sep 2022
    Huntington, IN
    For anyone wondering, Since the gauge was set up for a 33-240 sender, and Boyds doesn't offer one, The solution for the Boyds tank, sending unit and gauge was an Autometer fuel bridge, and a VDO sender. All is right with the world again
    https://www.summitracing.com/parts/VDO-226-625
    https://www.summitracing.com/parts/ATM-9109
  25. Likes RoadRacer, TxMike64 liked this post
