Added some Hagan Fatties on FFR arms
I bought those same Hagan Fatties, nice mirrors.
275's in the front are wide, but look mean! How do you think the 315's in the rear will fit under the fenders, or do you think they will need to be modified also?
Close enough
Had a little self inflicted set back. I drilled a hole in my fuel tank. So, great excuse to get a Boyd's tank. Ordered one this morning. Pulled the tank out last night.
Finished up the McQueen rear fenders last night. Didn't see how many fasteners to use so I did 7 using 1/4-20 rivnuts (deep reach for fiberglass) and stainless button heads on each one. Started 2" from each end and spaced 8.5" apart was the perfect layout.
Good job! Will be nice to see when it's back on the ground how the spacing of those big 315's look with the edge of the fenders.
While the tank is out, I took the opportunity to add a coating of the Boom Mat spray. This is my first time using this product and so far, I really like it. Nice thick coating that seems to do what it's intended to do. Did a little on the inner doors also.
Those fenders look great!
Installed the 3pt belts and removed the 4pt harness'. I think I got them installed correctly, didn't have any instructions.
For anyone wondering, Since the gauge was set up for a 33-240 sender, and Boyds doesn't offer one, The solution for the Boyds tank, sending unit and gauge was an Autometer fuel bridge, and a VDO sender. All is right with the world again
https://www.summitracing.com/parts/VDO-226-625
https://www.summitracing.com/parts/ATM-9109
