Thanks Thanks:  12
Likes Likes:  67
Page 3 of 3 FirstFirst 123
Results 81 to 96 of 96
Thread: Narly1's Speedstar build
    Jun 2020
    SoDak
    Looks great, but I'm almost afraid to tell you this.
    Normally (for any vehicle, not just the 33) you should not fully tighten/torque any of the suspension (front or rear) until the vehicle is fully built and the car is resting at full weight on it's wheels (no jack or jack stands). You could potentially (not always) get binding in the suspension.
    I personally also like to roll the vehicle back and forth a few times and push up and down on all the corners a few times before doing final tightening / torqueing.
    Jim
    Oct 2019
    Erin, Ontario CANADA
    Jim
    Thanks for the heads-up. I think I'll leave things as they are for now. My worst fear is that I'll forget to properly torque something down and end up with a safety issue. That and I can always revisit this closer to the end of the build, at the same time I'm doing my crude wheel alignment.
    Remind me again when that time comes LOL.
    Earl
    Oct 2022
    Binding of the suspension is associated with vehicles that have rubber bushings. Rubber bushings are bonded to the inner and outer shells and suspension motion actually twists and deforms the rubber. By waiting until the vehicle is at ride height to tighten the suspension avoids having the bushing deformed at ride height which avoids binding and premature failure.
    The 33 has poly bushings at all points of motion. They rotate on the inner sleeve which avoids binding. They all have grease fittings that lubricate this interface. There is no issue with torquing the suspension while it is unloaded.
  4. Thanks narly1 thanked for this post
    Likes narly1 liked this post
  5. #84
    Oct 2019
    The sum total of last night's activity was the assembly of these 6 suspension arm components in preparation for their installation onto the chassis.
    Between finding the documentation to be a bit lacking and having to search for some of the parts that ended up being in another box than expected I had my work cut out for me.
    Earl
  6. #85
    Oct 2019
    Rear axle and suspension install finished.
  7. Likes j33ptj, FF33rod liked this post
  8. #86
    Oct 2019
    Firewall and foot boxes installed using 1/4" button head fasteners. Steering rack and tie rods in. Pedal box and steering column partly done, waiting on EPAS kit and a different remote brake fluid reservoir. The panels will eventually be coming back out to be powder coated the same colour as the frame.
    Earl
  9. Likes TxMike64, Just 1 More, FF33rod liked this post
  10. #87
    Dreamer j33ptj's Avatar
    Wassenaar, The Netherlands
    You can always dab a little marker paint on the bolt/nut that you torqued up... visual aide de memoire
  11. Thanks narly1 thanked for this post
  12. #88
    Oct 2019
    Quote Originally Posted by j33ptj View Post
    That's a great idea as it serves as a visual indication that the fastener has been torqued!
    And also that it's not loosening after the fact.
    Earl
  13. #89
    Oct 2019
    A start to my mini-review of the EPAS system I ordered straight from China off of Alibaba.
    The lowest price I could find for a kit here in Canada was about $779 (~$573 US) before tax & shipping.
    This unit cost me about $565 (~$415 US). The kit is pretty bare bones, just the motor, control box and wiring harness. It comes with mounting bolts for both units and a few crimp connectors that I'll probably toss. No instructions or warranty card, etc. So I guess I'm on my own LOL.
    Otherwise it looks exactly the same as all of the 220W units available domestically. The box cast backing shows the same "IDK" marking the ones here have. Note that there is no mounting tab so I might have to make something up out of strip stock depending on where I end up mounting that.
    A quick check of the motor splines reveals that it is a 11/16-36. Ordered a couple of mating U-joints to connect to the kit supplied 3/4" double D shafts. These were $70 (~$52US).
    The only other issue that I can foresee coming into play is the length of the cables from the motor, they are only about 18" long, but should be easy to extend.
    P.S. Before flaming me on going cheap on a steering component recognize that the worst thing that can happen is that the unit stops working leaving me with just the "armstrong" steering I started out with. (The shafts on the motor are bigger than the ones on the steering rack, LOL.)
    Earl
  14. #90
    Simi Valley, CA
    Quote Originally Posted by narly1 View Post
    Earl
    There's a product available in the US called "Cross-Check Torque Seal" that is specifically designed for this purpose. I got it from McMaster-Carr ("Tamper and Vibration Detection Paint" on their website). However, the MM-C site says that they cannot sell it outside the US due to "local VOC regulations". IIRC, this joint loosening detection technique is used everywhere, so I expect you can find a similar paint from a local supplier.
    Keith HR #894
  15. Likes narly1 liked this post
  16. #91
    Oct 2019
    There's a product available in the US......
    Keith HR #894
    Thinking a regular paint (not ink) marker pen like this would work just fine:
    https://www.homedepot.ca/product/mil...ite/1001099367
    Earl
  17. Likes FF33rod liked this post
  18. #92
    Simi Valley, CA
    The Torque Seal sticks well to most materials and becomes very brittle when it dries, so it visibly cracks whenever a joint is disturbed. I have seen ordinary paint stick to one side of a joint and lift off from the other side without cracking - so it can be hard to detect loosening. Ordinary paint might work for this purpose, but then it may not. Seemed like a cheap investment to me.
    Keith HR #894
  19. Likes narly1 liked this post
  20. #93
    Oct 2019
    UPDATE: Finally got the correct spline pattern U-joints and got everything installed. Pretty straightforward other than I had to shorten the shaft between the firewall and assist motor U-joints.
    Once I got that sorted out I hooked it up to 12V and it works as it should.
    Earl
  21. Likes FF33rod liked this post
  22. #94
    Oct 2019
    So did I mount my remote reservoir too high up?
    The top surface of the cap sits below the firewall top edge.
    Earl
  23. #95
    Oct 2022
    Earl
    Yes, there is a feature on the hood that sits down in front of the firewall. With the reservoir that high it will interfere with the hood closing.
  24. Thanks narly1 thanked for this post
  25. #96
    Oct 2019
    Quote Originally Posted by Dgc333 View Post
    Thanks. I guess I'll leave it as is for now and fix it later when the time comes to fit the hood.
    Earl
