Added some Hagan Fatties on FFR arms
I bought those same Hagan Fatties, nice mirrors.
275's in the front are wide, but look mean! How do you think the 315's in the rear will fit under the fenders, or do you think they will need to be modified also?
Close enough
Had a little self inflicted set back. I drilled a hole in my fuel tank. So, great excuse to get a Boyd's tank. Ordered one this morning. Pulled the tank out last night.
Finished up the McQueen rear fenders last night. Didn't see how many fasteners to use so I did 7 using 1/4-20 rivnuts (deep reach for fiberglass) and stainless button heads on each one. Started 2" from each end and spaced 8.5" apart was the perfect layout.
Good job! Will be nice to see when it's back on the ground how the spacing of those big 315's look with the edge of the fenders.
While the tank is out, I took the opportunity to add a coating of the Boom Mat spray. This is my first time using this product and so far, I really like it. Nice thick coating that seems to do what it's intended to do. Did a little on the inner doors also.
Those fenders look great!
Installed the 3pt belts and removed the 4pt harness'. I think I got them installed correctly, didn't have any instructions.
For anyone wondering, Since the gauge was set up for a 33-240 sender, and Boyds doesn't offer one, The solution for the Boyds tank, sending unit and gauge was an Autometer fuel bridge, and a VDO sender. All is right with the world again
https://www.summitracing.com/parts/VDO-226-625
https://www.summitracing.com/parts/ATM-9109
I've been working on something different, Got it put together last night and fired right up. Didn't run it long, still have to do water lines, figure out how to run some stainless braid fuel lines and new plug wires. but.... IT RUNS!!!!
https://youtu.be/omqccc0eXOE?si=v_YEH-AEU3cTUtAR
Now that is cool! even if it is a Chev...
Gen 1 '33 Hot Rod #1104
That is bad a#$
33 hot rod,383 sbc tri power setup ,700 r4 transmission,gen1 body gen2 chassis
Did some timing tuning today, Removed the vacuum advance and locked the mechanical advance, set timing at 32 degrees and shes snappy and happy.
https://youtu.be/XHno2DRU5M4
Made a Manometer to fit the 4 barrel carbs so tomorrow I pay with the carbs and see if I can get them syncd
made fuel lines.. i'm kind of liking the old school red & blue vibe
Cross ram manifolds are the coolest looking but give up some horsepower to a tunnel ram. Very cool! Love it!
Pair of obsolete (and pretty rare) Arias Viper Scoops... because i like to be unique
Man, those just scream '60's Hot Rod! Way Cool!
Keith HR #894
WE GOT A VIN!!!!!!!!
Got my letter today from the BMV with an assigned VIN#.. now to continue with the process
Congrats! That's a big step. Just wondering, how did you make out with the rear McQueen bike fenders and your wide_ss tires? Did you modify the fenders or just adjust the rear ride height to clear them?
Great to hear. Any chance you can share a picture to see what those look like? I haven't ordered my wheels and tires yet, was kind of waiting to see how your 335's fit under the fenders first when the car is on the ground. I'm running an IRS, so my measurements might be a little different...
Here's what it looks like.. they're 315/35-20
