Thanks Thanks:  10
Likes Likes:  211
Page 6 of 6 FirstFirst ... 456
Results 201 to 238 of 238
Thread: # 1115 resurrection
  1. #201
    Oct 2023
    Yeah, not sure how the polished firewall is going to hold up. the new tires are definitely gravel kickers. My 383 came with the build but I had it re-built at NYE's racing engines. 401hp 437tq. What's your Skip White HP numbers?
    The 383 I’m looking at is advertised at 503 hp, 484 torque. I’ll know the actual when it arrives with the Dyno sheet. From speaking to Skip, at Skip White performance, it will be very street friendly. He’s used that combo often.
  2. Likes Just 1 More liked this post
  3. #202
    Sep 2022
    Huntington, IN
  4. Likes JimLev liked this post
  5. #203
    Placitas, NM
    I bought those same Hagan Fatties, nice mirrors.
  6. Likes Just 1 More liked this post
  7. #204
    Apr 2023
    Schott Accelerators
    Nitto 555 G2's
    18x9 275/40-18
    20x11 315/35-20
    Attachment 196614Attachment 196615Attachment 196616
    I'm interested in buying the McQueen bike fenders like you. Can't wait to see them on your car with those size tires and wheels that you have choosen.
  8. #205
    Sep 2022
    Huntington, IN
    Quote Originally Posted by cvacca View Post
    Not going to be so easy, I need to do some serious modification to the fronts to get the coverage I need. Tires are bigger than the fenders
  9. #206
    Apr 2023
    275's in the front are wide, but look mean! How do you think the 315's in the rear will fit under the fenders, or do you think they will need to be modified also?
  10. #207
    Sep 2022
    Huntington, IN
    The 315's will barely fit, might stick out a little but that's ok with me.
  11. #208
    Sep 2022
    Huntington, IN
  12. Likes Ltfracing, TxMike64 liked this post
  13. #209
    Sep 2022
    Huntington, IN
    Had a little self inflicted set back. I drilled a hole in my fuel tank. So, great excuse to get a Boyd's tank. Ordered one this morning. Pulled the tank out last night.
  14. Likes Ltfracing liked this post
  15. #210
    Sep 2022
    Huntington, IN
    Finished up the McQueen rear fenders last night. Didn't see how many fasteners to use so I did 7 using 1/4-20 rivnuts (deep reach for fiberglass) and stainless button heads on each one. Started 2" from each end and spaced 8.5" apart was the perfect layout.
  16. Likes Ltfracing liked this post
  17. #211
    Apr 2023
    Good job! Will be nice to see when it's back on the ground how the spacing of those big 315's look with the edge of the fenders.
  18. #212
    Sep 2022
    Huntington, IN
    While the tank is out, I took the opportunity to add a coating of the Boom Mat spray. This is my first time using this product and so far, I really like it. Nice thick coating that seems to do what it's intended to do. Did a little on the inner doors also.
  19. Likes TxMike64 liked this post
  20. #213
    Kingsland, TX
    Those fenders look great!
  21. Thanks Just 1 More thanked for this post
  22. #214
    Sep 2022
    Huntington, IN
    Installed the 3pt belts and removed the 4pt harness'. I think I got them installed correctly, didn't have any instructions.
  23. Likes TxMike64, 33fromSD, Ltfracing liked this post
  24. #215
    Sep 2022
    Huntington, IN
    For anyone wondering, Since the gauge was set up for a 33-240 sender, and Boyds doesn't offer one, The solution for the Boyds tank, sending unit and gauge was an Autometer fuel bridge, and a VDO sender. All is right with the world again
    https://www.summitracing.com/parts/VDO-226-625
    https://www.summitracing.com/parts/ATM-9109
  25. Likes RoadRacer, TxMike64 liked this post
  26. #216
    Sep 2022
    Huntington, IN
    I've been working on something different, Got it put together last night and fired right up. Didn't run it long, still have to do water lines, figure out how to run some stainless braid fuel lines and new plug wires. but.... IT RUNS!!!!
    https://youtu.be/omqccc0eXOE?si=v_YEH-AEU3cTUtAR
  27. Likes JimLev, TxMike64, Ltfracing liked this post
  28. #217
    Sep 2022
    Huntington, IN
  29. Likes FF33rod, TxMike64, Ltfracing, JimLev, 33fromSD liked this post
  30. #218
    Jun 2018
    North Vancouver, BC, Canada
    Now that is cool! even if it is a Chev...
    Gen 1 '33 Hot Rod #1104
  31. #219
    Sep 2022
    Huntington, IN
    LOL .. Thanks
  32. #220
    Senior Member Ltfracing's Avatar
    Aug 2022
    That is bad a#$
    33 hot rod,383 sbc tri power setup ,700 r4 transmission,gen1 body gen2 chassis
  33. Likes Just 1 More liked this post
  34. #221
    Sep 2022
    Huntington, IN
    Did some timing tuning today, Removed the vacuum advance and locked the mechanical advance, set timing at 32 degrees and shes snappy and happy.
    https://youtu.be/XHno2DRU5M4
  35. Likes Ltfracing, TxMike64 liked this post
  36. #222
    Sep 2022
    Huntington, IN
    Made a Manometer to fit the 4 barrel carbs so tomorrow I pay with the carbs and see if I can get them syncd
  37. Likes Ltfracing liked this post
  38. #223
    Sep 2022
    Huntington, IN
    made fuel lines.. i'm kind of liking the old school red & blue vibe
  39. Likes JimLev, Ltfracing, 33fromSD liked this post
  40. #224
    Jul 2020
    Spencer, MA
    Cross ram manifolds are the coolest looking but give up some horsepower to a tunnel ram. Very cool! Love it!
  41. Likes Just 1 More liked this post
  42. #225
    Sep 2022
    Huntington, IN
    Yeah, Horsepower was definitely not a consideration... lol
  43. #226
    Sep 2022
    Huntington, IN
    Pair of obsolete (and pretty rare) Arias Viper Scoops... because i like to be unique
  44. #227
    Simi Valley, CA
    Man, those just scream '60's Hot Rod! Way Cool!
    Keith HR #894
  45. Likes Just 1 More liked this post
  46. #228
    Jul 2020
    Spencer, MA
    Love it!
  47. #229
    Sep 2022
    Huntington, IN
    WE GOT A VIN!!!!!!!!
    Got my letter today from the BMV with an assigned VIN#.. now to continue with the process
  48. Likes RoadRacer, Ltfracing, JimLev, FF33rod liked this post
  49. #230
    Apr 2023
    Congrats! That's a big step. Just wondering, how did you make out with the rear McQueen bike fenders and your wide_ss tires? Did you modify the fenders or just adjust the rear ride height to clear them?
  50. #231
    Sep 2022
    Huntington, IN
    So far i've just adjusted ride height so they don't rub. I thought it would look stupid but it doesn't, at least not to me. I really like the look of a full tire in the fenders rather than small tires tucked inside of the fenders.
  51. Likes Ltfracing liked this post
  52. #232
    Apr 2023
    Great to hear. Any chance you can share a picture to see what those look like? I haven't ordered my wheels and tires yet, was kind of waiting to see how your 335's fit under the fenders first when the car is on the ground. I'm running an IRS, so my measurements might be a little different...
  53. #233
    Sep 2022
    Colorado Springs
    Nice work!
  54. #234
    Sep 2022
    Huntington, IN
    Here's what it looks like.. they're 315/35-20
  55. #235
    Sep 2022
    Huntington, IN
    Another milestone... Got the title in the mail over the weekend.. it's officially official.. It's Titled, insured and now tagged. The State of Indiana saw fit to title it as a...
    YEAR: 1933
    MAKE: Factory Five Racing
    Model Name: Roadster
    Body type: Coup
    Odometer: Exempt
    We are now street legal
  56. Likes FF33rod, Ltfracing, JimLev liked this post
  57. #236
    Simi Valley, CA
    Congratulations! Another major milestone.
    Now get out there and drive the wheels off!
    Keith HR #894
  58. Likes Just 1 More liked this post
  59. #237
    Sep 2022
    Huntington, IN
    And we're back to a single carb .. Unfortunately, I just couldn't get the crossram running good enough. SO to make life easier, back to one
  60. Likes Ltfracing liked this post
  61. #238
    Aug 2022
    Pm sent
  62. Likes Just 1 More liked this post
