Likes Likes:  5
Results 1 to 15 of 15
Thread: Summit T5 - Pull the Trigger?
    May 2023
    After trying to sorce a donor T5 and have it rebuilt, I think I'll go with the Summit option below:
    https://www.summitracing.com/parts/f...03-z/make/ford
    Any fatal flaws that I'm missing or should this do the trick? 302 rebuilt explorer motor, IRS from FFR with 3.55 rear end. No crazy HP numbers, just want something reliable for a transmission.
    Dublin, OH
    This is what I’m running with my 289. No issues
    That will work and the ratios are ideal for a 3.55 rear. Before pulling the trigger though check with Mike Forte and see what he can do for the same.
  4. Likes Geoff H, phileas_fogg, StangRacer liked this post
    Senior Member Rebostar's Avatar
    Jan 2024
    I put a TKX I got from Summit behind my stroked and bored (427) 351W. No bad issues at all, great outfit, great price, delivered in 3 days via UPS. Only go-carted so far but I'm very happy with it.
    Woodstock ,Illinois
    What Jeff said!!
    May 2023
    Thanks all, huge help!
    Nov 2023
    The only experience I have with a T5 was with a '90 Mustang GT. I was VERY disappointed with the way it shifted....it didn't shift "fast". I'm an old guy and I'm used to GM Muncie 4-speeds and Mopar New Process 4-speeds. They all used to shift effortlessly and fast. To be fair, I had heard that the problem was the stock Ford shifter and not the transmission itself.... and I never did try swapping out the shifter. And also, in the Summit description it mentions "short throw shifter". But still, I have a Tremec in my Cobra and it shifts like butter, just like my old 4-speeds shifted. Just sayin'
    Jan 2022
    Seven Hills, OH
    There is a big difference between the stock Mustang T5 and the T5Z that is being referenced.
    FFR3490 - MK2 Roadster: Yellow with black stripes, mildly built 5.0 with many upgrades/updates to come.
    See my build here: https://youtube.com/playlist?list=PL...6mVHNS3FsRV76S
  10. Likes ProfessorB liked this post
  11. #9
    Quote Originally Posted by ProfessorB View Post
    Interesting because that's the exact opposite of my experience and that reported by many others. Which Tremec do you have? Usually most feel that the T5 shifts like butter when compared to the Tremec 3650 or the TKO500 and 600. It has been improved with the TKX.
    O'Fallon, MO
    Agreed Jeff. The tremec I drove was like shifting a log truck, maybe the newer ones are better.
  13. #11
    Nov 2023
    Quote Originally Posted by Jrmotorsports55 View Post
    Thanks, I wondered as much. (It was referencd as "super duty"). I wonder if you might also know if swapping out the shifter on a stock T5 makes a big difference?
  14. #12
    I have a “super duty” T5 I got from a former vendor and I won’t do another one. I put a TKO600 in my 2nd build and liked it much better. Both used quality aftermarket mid-shifts.
    The TKO - now TKX - may be a bit of overkill for your power but better to be too strong than too weak IMO.
    Talk to Mike, he’ll give you good advice.
  15. #13
    Jan 2022
    Seven Hills, OH
    Yes, aftermarket shifter will tighten things up a lot and shorten the throws. The stock shifter is made for comfort, not accuracy.
  16. #14
    Nov 2023
    With the stock Mustang T5 shifter, it wasn't the length of the throw.... it was that it seemed to "hang up" halfway thru the shift. There was no way to shift fast...it would hang up in between gears if I moved the shifter too quickly.
  17. #15
    O'Fallon, MO
    The stock shifter had no shift stops, so when you shifted fast (power shift) you would bend the shift forks in the transmission due to over travel. The hanging up was likely due to bent forks.
  18. Thanks Jrmotorsports55 thanked for this post
    Likes Jrmotorsports55 liked this post
