Thanks Thanks:  7
Likes Likes:  37
Page 2 of 2 FirstFirst 12
Results 41 to 64 of 64
Thread: Scott's 65 Coupe Build - First Start Birthday Present
    Member slarson's Avatar
    Apr 2021
    Indian Harbour Beach, FL
    Foot boxes and a few weekends away
    With the body off I was able to get the footboxes drilled.
    Also got the radiator and Boig Cool tubes mocked up and tunnel aluminum drilled
    Then was out of town the last two weekends. A weekend skiiing up in North Carolina.
    Last weekend was camping at the ROLEX 24 in Daytona, we've been going for quite a few years now. To make it a special weekend, my son flew in from Colorado just for the race!
    Type 65 Daytona Coupe Complete Kit ordered 11/2021, delivered 7/25/2022....the fun has begun! Build Thread
    Apr 2021
    Coyote Coolant Expansion Tank
    I've been struggling to find a spot I liked for the Moroso coolant expansion tank. I was originally going to place it in the same location as Paul. But one fitting seemed to be in the way of the frame in front, and it also seemed to interfere with the air filter and intake.
    After quite some time moving it around and evaluating fitting and hose routing this seemed to be the best place, although not the easiest to implement.
    This location would require welding new mounting tabs on the sides of the tank, cutting off a mount on the bottom and fabricating a mounting bracket to pick up a third point on the tank.
    So into the scrap metal bin I went and came up with a plan. I've had the TIG welder for almost a year now, it was finally time to put it to real use as opposed to practicing. Not the prettiest welds but they are mostly hidden and will do the job.
    I'm very pleased with how it turned out and it is very solid. With plenty of clearance for the steering shaft and hoses.
  3. Likes Honeybadger liked this post
  4. #43
    Apr 2021
    Engine Bay Panels and the start of wiring
    It's been a busy spring with work being crazy (but the OT helps pay for car parts). And the annual trip to the Gatornationals that my son came home from Denver for, I think this was our 24th year in a row.
    Since the last update the focus has been on developing a plan for wiring and final placement of all things in the engine bay. I decided to mount the Coyote computer on the back firewall, so that meant the engine harness had to be reworked so it would reach the computer.
    Had to extend about 20 wires, not as bad as I thought it might be. Just time consuming and tedious.
    Next up was fabricating some additional aluminum panels.
    Mounted the Coyote fuse box up front by the battery. This makes more work(I seem to be good at doing that) but it just seemed to be a logical place to put it close to the battery. I also ended up choosing a remote battery disconnect that is cable actuated so it could be close to the battery.
    Also got the heater and AC hoses mocked up and cut to length, nothing crimped yet though. To solve the issue of the AC bulkhead fittings not lining up with the evaporator fittings was to remove the bracket that holds the two bulkhead fittings together. I cut D shaped holes in the panel, placing them as close together as possible. Everything seems to line up ok. Also chose to mount the heater valve inside the footbox, still need to fabricate a mounting bracket for that.
    So far I'm happy how things are turning out.
  5. Likes 460.465USMC liked this post
  6. #44
    Apr 2021
    The other London...
    Not build related, but an incredible experience for my wife and I was a trip to the U.K. last month. The primary purpose was to run the London Marathon. All I can say is what an experience!!! We have run the major marathons here in the US and the crowds in London were over the top! We have now both completed four of the six Major Marathons in the world, just Tokyo and Berlin remain (and we are scheduled for Berlin this fall).
    A small sample of the incredible places we experienced.
    Westminster Abbey and the clock tower where Big Ben lives (Big Ben is the nickname of the bell)
    Windsor castle, the lower portion built in 11th century
    Also visited Edinburgh for a few days
    Now back to the build!
  7. Likes 460.465USMC liked this post
  8. #45
    Senior Member 460.465USMC's Avatar
    Aug 2019
    Spokane, WA
    Hi Scott. Just read through your build. I think you're making great progress, and not a little ingenuity along the way. Your build looks really clean, and professional. Keep up the good work. I'm subscribed and looking forward to your next progress update.
    P.S. my wife and I are just finishing up The Crown series on Netflix. Probably about as close to London as we'll get. So cool you and your wife saw it in person, and checked off another big marathon. Impressive.
    Coupe complete kit delivered: 4/22/24. Build Thread. Coyote. T-56. IRS w/3.55. Wilwoods. PS. HVAC. Side windows.
  9. Thanks slarson thanked for this post
  10. #46
    Indy Shu's Avatar
    Indianapolis, IN
    Scott,
    Your build is looking good. A couple of thoughts looking at your updates.
    1. I also put the heater valve inside the footbox. It's a tight fit and with hoses coming out both sides I didn't see the need to mount it to anything as it seems very secure.
    2. With regard to the oil cooler location, I can tell you just from a few heat cycles in the driveway, when the fan comes on that air is HOT! Would be nice to mount the cooler in front or in a different spot, but not a lot of options. Maybe the concentration of heat won't be as bad while driving down the road. I put a small steering fluid cooler on the engine side of that panel.
    My 27 yr old son who lives in Boulder is also a runner. Has run Chicago and Boston, among a few smaller ones. I think he's shooting for Berlin sometime soon. Has one in Ogden Utah this Saturday.
    Gen 3 Coupe #334 received 11/4/21. Coyote, IRS, TKX, Wilwoods
    '02 GT donor, 4.6 sohc, Received #5488 on 5/29/06. 3-link, ps, pb. Hoosier Cobra member (Hoosiercobra.com)
  11. Likes slarson liked this post
  12. #47
    Apr 2021
    Thanks Chris, some friends we traveled to London with mentioned the Crown series. I wish I would've know about that before our trip, they said it helped provide a lot of history about the things we were seeing. We also couldn't help but notice just how nice everyone was!
    Quote Originally Posted by Indy Shu View Post
    Scott,
    John, thanks for the input. I looking at the heater control valve over the weekend, trying to determine how best to fabricate a bracket to hold it and came to the same conclusion.
    I was concerned about location of the PS cooler and the hot air coming out of the radiator. Obviously I'm committed so we'll see how it works, worst case I can always fabricate some ducts to bring cool air to it
    And congrats to your son, and definitely have him add the London Marathon to his list!
  13. #48
    Mar 2021
    Ohio
    Your build is looking super nice! I also put the bypass switch inside, but pushed out the footbox to get it tucked in, and also to be able to close it off to try to keep the heat out of the footbox. I was able to use the supplied bracket, but ended up bending the top mounting tab in 180 degrees, put in rivnuts, and put screws in from the outside.
  14. #49
    Apr 2021
    Quote Originally Posted by burchfieldb View Post
    Thank you! I didn't think about modifying the footbox, great idea. I plan on putting insulation on the heater hoses inside the footbox to cut down on the radiated heat.
  15. #50
    Apr 2021
    Radiator and Condenser mounting
    Finished the final details of mounting the radiator and Condenser. I am using the same condenser that Paul and others have used, Vintage Air part number 03263-VUC.
    To start, I wasn't wild about the skinny brackets and slit fuel hose that the radiator is supposed to rest on. I decided to form and weld in some some 0.040 sheet metal U shaped pieces for the radiator to sit in. Those are then lined with Radiator Rubber Mounting pads from Summit (part number SUM-380666).
    Also welded in some 1/4" think metal bar to protect the bottom of the radiator, thanks to Rsnake for this idea!
    Painted with POR-15 and rubber pads installed.
    Didn't like the idea of a button head screw possibly banging into the radiator so I decided to use flat head screws for the condenser straps.
    Using the same rubber pads under the strap that holds the top of the radiator. To account for the added thickness I had to make some shims to go under the strap.
    Left side:
    Right side was a little different, I didn't like the angle the strap had coming down to the frame:
    Now the strap runs down along the side of the radiator. From inside the radiator tunnel:
    Finally, I didn't like the plastic spacers for mounting the evaporator so I purchased a 1/2" x 5/8" aluminum bar. Four holes and I like it much better:
  16. Thanks 64badger thanked for this post
  17. #51
    Apr 2021
    Finally back at it
    After an unexpected year off from the build(for good reasons), I'm back at it!
    In June of last year my wife decided she was tired of the beachside barrier island area where we lived due mainly to traffic and noise, not to mention ridiculous insurance rates. We found a newer house on almost 3 acres about 20 miles south in an equestrian community, and as a major bonus it had a 1500 square foot building!
    So began the scramble of buying, selling and then the moving. We've been in the new house 11 months, after getting settled into the house a lot of time was spent moving into the shop and making it useable. I'm not done (probably never will be) but it's at a point where I can spend time on the Coupe again. The last few months have been spent getting reacquainted with the car and figuring out where I left off.
    The back yard:
    The shop, started with just an empty metal building and only 6 outlets, and no 220V drops. So added four 220V outlets, two additional circuits of 120V outlets, Plywood on the walls, made and installed cabinets, bought more cabinets, made shelving and this is the current state:
    More to come about the progress that has been made on the kit. The major accomplishment was the engine bay aluminum went out and is back from powder coating!
  18. #52
    Aug 2019
    Spokane, WA
    Welcome back, Scott. I can't believe it's been over a year since your last build update. I really enjoyed following your build last year. Will be taking some notes since my Coupe build is now underway.
    I hear you on the house move. I did the same thing. Been in my "new" (built in 1907) place for 10 months. I also inherited a metal building. It was an empty shell. So, spent the entire winter getting it up to speed. It's much smaller than my last garage, so every square inch has a purpose.
    Looking forward to seeing your build progress. Just received my Gen 4 Coyote. Trying to figure out how to get it off the pallet using my HF engine hoist. The pallet is too wide for the hoist legs. Will probably cut down the pallet with my Sawzall in order to slide the hoist into position.
  19. #53
    Apr 2021
    Thanks Chris, it surprised me how long it took to get a new shop space organized and functional! Mine is bigger than my previous garage, I can't imagine having to go from large to smaller. That would be no easy task!
    My Gen 3 Coyote was mounted to a small metal stand that was mounted to the pallet. If I remember right I was able to unbolt it and slide the engine towards the corner of the pallet and the engine hoist straddled that corner and was able to pick it up. Then I cut down the pallet so it would fit between the engine hoist, put casters on it and used that to store the engine until it went in the car.
  20. #54
    Aug 2019
    Spokane, WA
    Good idea to slide it toward a corner. Didn't think of that. Not sure it would have made a difference in my case, as that would take some serious muscle!
    It was Sawzall to the rescue. Was able to narrow the pallet so the hoist could straddle it.
    Good to have it off the pallet. I like your idea of putting it on casters. As I mentioned my new garage space is much smaller (half the square feet). Easily moving it around would be big help. Thanks for the idea!
    This Gen 4 looks an awful lot like a Gen 3. Really can't see any difference so far, besides the reported header flange bolt pattern difference on the left side.
    Sorry to hi-jack your build thread for a minute. I'll be quiet now. Happy building!
  21. Likes slarson liked this post
  22. #55
    Apr 2021
    Making Progress, working towards first start
    I've been hard at it, but I am way behind in updates.
    • Engine compartment panels are back from powder coat (post on how I filled unwanted holes to come)
    • Footbox and engine compartment aluminum panels are installed
    • Brakes are bled
    • Fuel lines and regulator are back in and double checked to be tight
    • Engine and transmission are in for the final time
    • Engine PCM is mounted and wired
    • Fuse box is in and wiring is at least separated and routed to front, rear and dash
    Fuel Regulator and fire suppression lines
    I choose not use the standard Ron Francis wiring harness, mainly because I wanted extra circuits for various functins I wanted to add. After much searching I decided to go with the KwikWire 22 circuit harness.
    So far I am happy with that decision. Once the fuse box was mounted I struggled with how to route the various groups of wires as they were grouped out of the box. I finally came to the realization that this is not a typical installation so their grouping/routing wasn't going to work for me. Once I cut all the zip ties and had just a mess of wires, the sorting, organization and routing became much easier.
    Fuse Box Mounted and drip cover
    Wires from fuse box back into car. Top view of fuse box drip guard
    The first electrical connections
    Just A few wires to go
  23. Likes PNWTim liked this post
  24. #56
    Apr 2021
    Filling unwanted panel holes
    Most, if not all of the FFR sheet metal screw holes used to mount the panels for shipping didn't line up with my rivet spacing. So I quickly gave in to the fact that I would need to fill the unwanted holes and moved on with drilling and fitting panels. I searched for solutions and found many that some claimed to work but none that sounded like they were guaranteed, other than TIG welding which I attempted but am nowhere near good enough. So I choose to fill the holes with Low Temperature Aluminum Welding Rods from Harbor Freight.
    First I used my hold deburring countersink tool to create a bevel/countersink on each side of the panel.
    Then using a propane torch, heated up the panel until the rod flowed into the hole, kind of like soldering, heat is slowly until the metal is hot enough to melt the filler. This took a few practice runs but was quick once I got the hang of it.
    Top side after adding filler:
    Bottom side after adding filler:
    Then sand the filler down with 50 grit followed by 120 grit sanding disks in a 4.5" angle grinder. This is where is pays to go slow and remove a little at time.
    This was one of the trial runs, my technique got better as I went.
    Final result and I can't find any of the repairs in my coated panels. There was a filled hole just right of the top center rivet.
    I'm sure the textured powder coat helps hide some imperfections.
  25. Likes jbs72697 liked this post
  26. #57
    Senior Member JimStone's Avatar
    Nov 2022
    Niles, MI
    Quote Originally Posted by slarson View Post
    That's pretty cool.
    Those self tapping screw holes from the factory really irritated me. I wish they'd just tape the panels, or leave them off the body, instead of having to deal with of their haphazard holes everywhere
    I might try your method
    Gen 3 Coupe #576 - "Project Deimos"
    Ordered: 2/14/2024
    Received: 5/24/2024
    Build Thread: https://thefactoryfiveforum.com/show...upe-has-landed!
  27. Likes slarson liked this post
  28. #58
    Mar 2021
    Ohio
    Glad to see this worked. This was also the plan I had to try to fill the holes, but had not got around to it yet.
  29. #59
    Apr 2021
    Yes, it was actually quicker and easier than I thought it would be. Just have to go slow with the grinder and practice a few time on scraps before attempting a real panel.
    I can't see a single patch in my panels, although I did go with a textured powder coat so that helps hide imperfections.
  30. #60
    Apr 2021
    Saving partially used Silkaflex caulking tubes
    I stuck a nail in a partially used tube of Silkaflex a few months ago, hoping I would be able to use it later.... Well, I tried to get the nail out and it wouldn't budge. So I had the thought of slicing the tip length wise to see if the nail and dried up caulking would come out. Sure enough it worked like a charm.
    The to fix the tip I just put on two pieces of heat shrink tubing, worked like a charm.
  31. #61
    Apr 2021
    Protecting Braided Sleeving when installing Heat Shrink tubing
    The braided expandable sleeve I'm using to cover some hoses and wiring seems to have a low melting temperature. I've noticed it start to melt when shrinking a piece of heat shrink to finish off the end.
    I had a few small pieces of Thermo-Tec Express Sleeve left over so I tried using that as a shield around the braided sleeving. Worked like a charm!
    The Express Sleeve is a velcro closure so super easy to put on and take off.
  32. #62
    Apr 2021
    Horn Mount Bracket
    There seemed to be a nice empty space behind my battery to mount the horns, just needed to fabricate a bracket from some scrap metal lying around.
    A piece of 3/4" angle iron and a two short pieces of 1.5" x 1/8" flat bar.
    Horns mounted
    And two 1/4" rivnuts into the frame triangluation bars and good to go.
  33. Likes 460.465USMC, PNWTim liked this post
  34. #63
    Apr 2021
    First Start Birthday Present!!!
    My son has been home for a few weeks and we've been cleaning up loose ends in prepping for the first start.
    After a few setbacks and trouble shooting the first start occurred Monday and it just happened to be my birthday
    Now all that's left is everything else!
  35. Likes PNWTim, JimStone, 460.465USMC liked this post
  36. #64
    Aug 2019
    Spokane, WA
    Wahoo! Congrats, Scott! And, happy birthday! Very cool it all worked out to fire it off while your son was there.
