Likes Likes:  2
Results 1 to 15 of 15
Thread: E-Stop Location
    Dec 2023
    Eddyville, KY
    E-Stop Location
    I have not got the engine or floor pans in and I thought, if I was going to use an alternate location for the E-Stop, now would be the time to do it. What are some of the locations folks have used and what additional parts or cables were required?
    Jim
    Dec 2020
    Washington, MO.
    I have put mine just below the 3/4" tubing just beside & behind the shifter location.
    Turned the mounts upside down & used rivet nuts to anchor it right through the frame..
    The only additional part needed was the Lokar cable block.
    Cut off enough cable to shorten it to fit my desired location.
    Just watch where you pick for the handle. I put mine a little to close to the shifter boot.
    I did get the rear brakes offered from FF not Wilwoods.
    Feb 2022
    Flower Mound, TX
    I used a somewhat unconventional location, but it worked really well.
  4. Likes M22_COBRA liked this post
    Dec 2023
    Eddyville, KY
    OB6 I like it. Are those the stock cables
    Jim
    Senior Member MB750's Avatar
    Feb 2022
    Tampa, FL
    Here's how I did it. DIY all the way:
    https://thefactoryfiveforum.com/show...l=1#post566491
    Matt
    My build thread here
    Feb 2022
    Flower Mound, TX
    Quote Originally Posted by Wingman06 View Post
    Jim, yes they're the stock cables from the 2015+ Mustang. I had to modify the lengths a bit, but it's not difficult.
    I would NOT put it in the transmission tunnel. Just think how difficult it'll be to service it, or adjust the cables. Crossways in the trunk or like OB6
  9. Likes Mike.Bray liked this post
  10. #8
    Feb 2022
    Tampa, FL
    The top of my transmission tunnel is held in place with rivnuts and SS bolts. Quickly removable.
    Matt
  11. #9
    Senior Member Lidodrip's Avatar
    May 2020
    Yarmouth, Maine
    I have mine in the same place as OB6 - works great and easy access.
  12. #10
    Feb 2022
    Flower Mound, TX
    Quote Originally Posted by Lidodrip View Post
    Where do you think I got the idea? LOL. I should have given credit in my post above.
  13. #11
    May 2020
    Yarmouth, Maine
    Quote Originally Posted by OB6 View Post
    Ha! No credit needed - it was fun to see someone else put it there, glad it worked out for you.
  14. #12
    May 2023
    My location:
    Going to add an access panel in the trunk to make servicing easier.
  15. #13
    Louisville, KY
    Quote Originally Posted by jbow03 View Post
    My location:
    This is where I mounted mine as well. IRS rear suspension. I thought about an access panel in the trunk, but it's not too difficult to service from under the car.
    2nd 289 Build In progress. 302, midshift T5, IRS, 15" Halibrands
  16. #14
    Sep 2024
    Michigan
    @OB6
    Did you notice any binding of the actuator in this location between the reaction bracket and mechanism? It looks like the cable take a bit of sharp bend to meet this location, however I really like this location otherwise.
  17. #15
    Sep 2024
    Michigan
    @Lidodrip
    Did you notice any binding of the cable between the reaction bracket and actuator? I like the location, but the angle of the short cable looks like it may bind when releasing tension from this image.
