Thanks Thanks:  2
Page 10 of 10 FirstFirst ... 8910
Results 361 to 367 of 367
Thread: THE Wheel & Tire Thread
  1. #361
    San Diego Ca 92106
    Thanks for the info.
  2. #362
    Sgt.Gator's Avatar
    Bend, Oregon
    Hoosier is the maker of Continental racing tires. Continental will no longer be sponsoring the Continental Tire SportsCar Challenge next year, Michelin has taken that sponsorship at IMSA. The result is we can buy left over new Continental Race Tires now at a good price from Hoosier, and probably will only get better, as the 2018 season comes to an end. Not only are the prices good, exceptional really, but the shipping is very cheap. $15 total whether you buy 1 or a dozen. I've already received a bunch for my STI and Palatov, some of the available sizes may work for an 818. These are full on racing slicks in both wet and dry versions. They are not DOT approved for road use!
    https://shop.hoosiertire.com/index.p...it-racing.html
    Owner: Colonel Red Racing
    818R ICSCC SPM
  3. #363
    Senior Member Mulry's Avatar
    Dallas
    Received our wheels a couple weeks ago. Team Dynamics ProRace 1.2. Fronts are 15x7 to prevent rubbing on the tub, rears are 17x9. Purchased through DemonTweeks in Wales, UK, and they shipped to Dallas. Was great working with them. Look forward to putting slicks on these:
  4. #364
    Quote Originally Posted by Mulry View Post
    Mulry,
    I am also running Team Dynamic wheels. My size is 17 x 9 - 45 et on all four corners. My tires are 235/40 front and 255/40 rear. 15mm spacers on rear.
    Do your 15" front wheels have any problem fitting over the brakes. If you get a chance, can you take a picture of the brake clearance.
  5. #365
    Syracuse, NY
    Also interested in the front brake clearance! Please post pics when you can.
    MK3.1 Roadster completed 2011
  6. #366
    Senior Member BigDanSubaru's Avatar
    May 2021
    York, PA
    Front: 18x8 +45 Storm Grey Enkei Tuning TS-V
    Front: 215/35ZR18 Michelin Pilot Sport 4S
    Rear: 18x9.5 +45 Storm Grey Enkei Tuning TS-V
    Rear: 255/35ZR18 Michelin Pilot Sport 4S
    Running the VCP lower control arms for the extra clearance. Wheels currently hitting the rear upper control link. I am going to try putting both spacers to one side to offset the link for more clearance. If that does not give me enough, I'll consider adding 5mm or 10mm spacers in the rear.
    Update: Offestting the rear upper control links helped slighly, but it just doesn't feel right to install them that way. I am going to just order 10mm spacers for the rear with extended wheel studs. I test fitted using stacks of flat washers and 10mm will provide the needed clearance. I just hope they fit under the rear fenders. Won't know until I get the body all lined up and get the car aligned.
  7. #367
    West Suburbs of Chicago
    Quote Originally Posted by BigDanSubaru View Post
    Goodness, those rears look soooo wide without any bodywork. I picked up a a set of F5 wheels during my buil. Interestingly enough, they no longer sell them. That being said, they are certainly wide enough. Currently trying to decide on another set. Not sure they will stay staggered like the F5 units but depending on size of tire and use of spacers, I am hoping to maybe go 17” all around. Also just upgraded to wilwood bbk @ all 4 corners, and since the pay fit under Subaru factory wheels, just trying to find a light, strong and lower cost alternative with good tire options..IMG_1641.jpgIMG_1098.jpeg
