I am using the kit-provided
clutch and brake reservoirs. In the last post, I mentioned where they were going to be installed—in the panel right in front of the driver's footbox.
For those of you who have these or have installed them previously, you know the provided installation brackets have ears, and you use button head screws to install them vertically. Well, the space in this location wouldn't support that. As such, I decided I needed to make my own bracket. I cut the ears off using my
band saw, sanded them smooth with the
belt sander, and purchased 1/8" (I thought 1/16" would be too flimsy, but 1/8" worked well)
L-channel from Lowe's.
My initial thought was to drill through the Factory Five-provided brackets and then mount them to the
L-channel using 1/4" flathead screws and lock nuts. However, I was concerned that this could result in some movement. Since this was going to be installed through the top panel, I decided to drill and tap the holes—meaning the screw would go through the provided brackets and then be held to the
L-channel with a lock nut.
After this, I used the band saw to eliminate the material required for the reservoirs to be installed on the L-channel, and cleaned that up with the
belt sander (don't have a picture with it done but here is the pre completed picture to illustrate):
You’ll notice that the spacing on the brackets isn’t consistent. This was intentional to make it obvious which is for the front and rear brakes and which is for the clutch.
I then determined where the reservoirs and bracket would mount and drilled holes for future 3/8" rivet mounting. Make sure there’s enough room to get a drill bit and rivet tool in there. Also, ensure the bracket is installed low enough to allow for engine vibration, even when it's in place.
Once held in with
Clecos, I used a 2.5" hole drill bit to drill through a piece of 3/4" plywood. I then used the round piece of plywood as a guide by placing it into each reservoir mounting bracket and drilling a pilot hole through the top panel. Once the pilot hole was completed, I used the same hole cutting bit to drill the hole large enough for the reservoirs to poke through the panel. It came out AWESOME! - obviously they will be installed level but will work on that during the final installation process:
My original plan was to do a round-over punch, but the holes were too close together for that to work. I’m thinking about using some sort of ring around them—possibly stainless or something similar—but have been unable to find something that works. Suggestions would be greatly appreciated! For now, check this box as done.
