Nice, happy building!
MK IV Delivered June 27, 2023 Build Thread-https://thefactoryfiveforum.com/showthread.php?46069-Lance-s-Roadster-Build-Thread-Starting-the-Al-panel-slog
"Build a Car" They Said "It Will Be Fun "
Thought I would post an update since my kit arrived yesterday. I have done some fine tuning to my build sheet and getting closer to what I think is a better overall picture:
2025 Gen 4X Coyote Crate Engine and Controls Pack
Gas’n headers and side pipes (probably ceramic coated white)
QuickTime bell housing
Ford Racing billet steel flywheel
Ford Racing / Centerforce dual friction clutch
Tilton 6000 hydraulic throw-out bearing
Tremec Magnum T-56 6-speed transmission (2.66, 1.78, 1.30, 1.00, .80, .63)
3.73 Torsen 2015+ IRS center section (LKQ to the rescue)
QA1 double adjustable coil overs with 600/350# springs (I have the Koni’s as well)
19” wheels – I have been looking at Forgestar, Forgeline, Schott, CCW and Forgiato
Tires – looking at Michelin Pilot 4s, Firestone Firehawk and Toyo
Heater, defroster, and A/C (FF supplied)
Breeze fan shroud
Hydraulic power steering (Thanks Paul)
Manual brakes with kit supplied Wilwood pedal box – Baer or Wilwood, still up in the air on this one
NiCop fuel and brake lines, Pro-M 3/8-inch fuel pump hangar, Trick Flow filter
Full aluminum panel powder coat and key area insulation, possibly Lizard Skin
Moroso expansion tank
Boig Cool Tubes if I can get them (seems like I can)
Specialty Power Windows WWK-2 Universal wiper kit
Bespoke-esque interior (think Singer with touches of E Type)
Nisonger instruments
Heated seats (seats themselves TBD)
i.e.427 Turn Signal
All LED lighting, courtesy lights, backup light
Integrated phone charging and magnetic holder
Drop trunk mod with a hinged cover
Door Poppers from Autoloc
Arcadian/Gulf/Viking blue with white stripes and associated meatballs, markings, the works.
Really going for the “refined comfort race car” if that’s a thing. We’ll see. When I built my previous car, I changed my mind on major details more than once which I am trying to avoid here as it’s time consuming, costly and a general PITA. I have been thinking about this car for quite some time so I think I am well acquainted with what I am shooting for as well as what is out there combined with my skill set. There is an urge to add a lot of bells and whistles but I am trying to walk the line between too little and too much.
For what it’s worth, I have come to the conclusion there is benefit to the waiting period (although moderately agonizing) simply because you can do a deep dive into the smallest of details and consider all options without feeling pressured to move the pile forward. My wait time is pretty short compared to others but I tried to make good use of it.
I have also spent the last couple of weeks trying to organize my garage and make a little space but that’s still a work in progress. More to come.
Coupe complete kit ordered: 9/26/24. Gen 4 Coyote. T-56. IRS w/3.73. Wilwoods. PS. HVAC. Side windows.
Congrats!
Build 2: Gen3 Coupe Complete Kit #309 Ordered 1/25/21, Delivered 6/9/21, CA SB100 Registered 8/27/24 - BluePrint GM 427 LS T56, IRS, AC, Power Steering. Album Here
Wahoo! Early Christmas, indeed! I think you're going to have a blast with this project. Eric also delivered my Coupe. Very helpful guy!
P.S. fantastic color on the Camaro! One of my favorites.
Coupe complete kit delivered: 4/22/24. Build Thread. Coyote. T-56. IRS w/3.55. Wilwoods. PS. HVAC. Side windows.
Thanks for the update. I was just trying to figure out if I needed to call about it. I will wait some more. I am not in a hurry. I am still working on the front suspension.
Coupe Complete Kit - Ordered 7/8/24 - Received 10/13/24
So I finished my inventory today which I thought was actually pretty fun. Didn't find anything missing other than my headliner. I didn't go so far as to test electrical items but everything is there with the exception of a fairly large misunderstanding/oversight on my part. I didn't order the 3.55 pumpkin from FFR since I wanted to install a 3.73 Torsen and they don't offer it. Well, unbeknownst to me, if you don't order the diff you don't get the spindles or hubs which in retrospect seems kind of silly since I purchased the IRS kit. So now I need to source those from the aftermarket but need to figure out exactly what I need.
If anyone knows the specifics of the knuckles and hubs I would appreciate it. Thanks in advance.
Hi Tim. Here's a couple pictures of the part numbers for the IRS hub and knuckle. This is from my Roadster build, circa 2020. But, I got the same parts for my current Coupe build, so this should get you there.
Too bad about the misunderstanding. In the kit description "Optional 2015 IRS Parts Needed" IRS knuckles/hubs are listed, and the optional part number 16668 on the order form lists Center Section, Spindles, and Hubs. Lots of details to sort through, so probably won't be your first surprise. The information you received is correct. Ford Performance sells the parts as M-5970-M. Since they have the main bearings for the rear axles, I'd recommend getting new. Shop around. There are some discounted prices out there.
I don’t recall exactly if this is the “knuckle”, thought it is.
Extra , new , passenger side.
Yours for shipping if you need it.
Coupe Kit Delivered 11/10/23
Roadster Build thread: 2019-2022 https://thefactoryfiveforum.com/show...4-Build-Thread
Thanks Paul. Truth be told, I found the ordering process somewhat ambiguous. The descriptions are a little generic and without your previous experience it's kind of hard to tell what you're getting or not. When I did my inventory over the last two days I was surprised I was shipped an accelerator pedal and throttle linkage even though I ordered the Coyote kit. You are absolutely correct in that the description says Center Section, Spindles and Hubs but I think at that point I was lost in the weeds.
It would be nice if the ordering process was a little more interactive in the sense that if you select the IRS it warns you to order the pumpkin and etc. I had somewhat the same issue with the power steering. If you hadn't told me I wouldn't have known the KRC stuff came with it. Live and learn I guess.
Yeah, this forum is a mandatory secondary instruction manual. I can't image trying to do this without the forum.
Gen 3 Coupe #576 - "Project Deimos"
Ordered: 2/14/2024
Received: 5/24/2024
Build Thread: https://thefactoryfiveforum.com/show...upe-has-landed!
So, I recently gave up on the idea of the 3.73 Torsen used center section. I have been shopping for 3 months and haven't found one with less than 25,000 miles. I know that isn't much in the big picture but made the command decision to go with a new 3.55 limited slip (I know, I give up some of that lower end zip but start with all new). I needed to order knuckles anyways so put together an order and received it yesterday. Unfortunately, the boneheads that shipped it took the Ford Racing box and laid it on it's side in the over pack box and most if not all of the gear oil and friction modifier leaked out and made a significant mess.
So my question is, after I clean up all the stink, I am thinking I will top off with maybe 1.5 ozs FM and the remainder gear oil, bring it to within 9 mm of the plug and call it good. I am thinking it is going to take at least a pint and half if not two based on the amount that was released. Does anyone see anything wrong with this?
Hi Tim, I may have the part bottle of gear oil if you get the Ford part. Let me check before you buy, free to a good home!
How's the build coming along?
Haven't really done anything but get more organized and figure out my plan. My son is coming home for the holiday so probably going to make a little progress this next week. Planning on taking the body off, storing it away and removing all the aluminum. I will probably start painting and assembling the suspension and steering shortly thereafter.
