So, we have driven another 30+ miles and our cooling system seems to be working, fingers crossed !!
We had upgraded to the fancy FFR shifter with our original order. I really like the way it looks. I went ahead and hooked it up as per the manual but had a negative attitude about the function of the 270* turns the cables need to make, and sure enough we weren't happy with the performance. There are multiple posts/threads on this issue. SO, we turned the shifter around and measured lengths. Multiple skilled and advanced builders have posted that they used an 84" push-pull cable but I measured and that didn't seem to pencil out...
With the shifter in a good position for use here are our measurements.
Here is what I wound up with
It works great!
Here is a link to my Youtube video
https://www.youtube.com/watch?v=cDqTAwI7AmY
Thanks for this Mark. Timely. I was looking at doing the same thing for the same reasons. At least this is a good heads up that some variation in length is to be expected. Not like we're building custom cars here or anything... =)
Personally, I think the FFR shifter looks even better in the reversed orientation. Nice work.
My Brother in-law came into town a few weeks ago and we worked on the Exhaust. We welded in this Magnaflow muffler I got from Summit.
Sounds great!
https://www.youtube.com/watch?v=o2ThRtHXZcQ
Nick and I wrapped it with titanium wrap last weekend.
With help from forum members I got the headlights, DRL, and blinkers functioning. Here's a video
https://www.youtube.com/watch?v=gkBU8YpLgVU
The Hella headlights wouldn't fit into these buckets so I did this modification which I think originated from Aquillen???
I made my own studs and epoxied them in place.
I reinforced the bucket with extra brackets and am very happy with it overall.
finally, installed studs on the inner fenders to hold the headlight assembly and allow easy removal. We epoxied one side and used High Strength filler on the other. Nick did all this work.
My opinion is that the 3M filler is easier to work with and holds well. I used it on the MK4 and after over 5000 miles no problems
Over the break Nick and I got in some good wrenching time. We noticed a leak in these lines. cold weather. I figured it was rigged enough and time for more permanent solution
Here are the Gates PowerGrip hose clamps
Nice work. Great to see build is still going and getting in time with your son.
Coupe Kit Delivered 11/10/23
Thanks Mike, Yeah we're still at it. Nick is a senior and more engaged in the build than ever. I am determined to finish this thing before he graduates. Including paint. My MK4 still isn't painted.
Nick wanted to use this photo for his senior photo. I told him he needs to put on a tie. At least he managed to cut his hair, sort of, lol...
An outstanding sound system is an absolute must in all of my vehicles.
I found a great deal at Crutchfield on this head unit with a back up camera.
I also got a powered subwoofer which will fit behind the passenger seat.
I'm using the speakers from the donor which were after market upgrades and seem to be in good condition. If they don't perform I will upgrade further.
I fabricated a bracket for the head unit. It is a little intrusive on the passenger side but oh well...
Nick and I have been chipping away at the body work for a while. i have enjoyed it because he can come in on days I'm not there and get work done.
It's coming together better than I thought it would. I need to figure out some sort of "tab under the panels system" to close these gaps.
For time sake I don't want to go crazy with the doors. Just need them functional with functioning windows. However, I am thinking of plugging in to the actuators
Have you considered camloc fittings as a "tab under the panels" solution?
I'm a huge fan of them. They are not cheap, but they are small and man do they hold strong (the 2600 & 2700 series are fine for most applications, but if you need a really strong hold the 4002 series are very robust). If you aren't familiar with them, it can take a bit of time to get a sense of how they work. You also need either (a) a wide range of stud sizes, or (b) pretty precise measurement of your combined panel thickness.
It seems to me the critical part of the door has to do with the frame alignment being as accurate as possible. The door skin appears to be a wobbly amorphous exostructure which needs to be one paint stick away from the body. I figured I would try to set up the door frame to be 2 paint sticks from the body and as even as possible.
I had to raise the top a little and pull it forward slightly on the driver side.
Not sure yet how it will affect the interaction with the fenders
It is important that you install fenders and hood before the doors.
I use a straight edge about half way up my door to verify flushness with side sail and fender.
Notice that the exposed door sill get wider toward the front of the door.
Click on images below to enlarge.
Fun to watch you and your sons project, what a great experience for him. Looking forward to seeing it all painted up! Will this be his daily driver? What color are you going with?
McCam, I spent at least 40 hrs on each door getting the windows operating to my satisfaction. They’re a real fiasco. Body fitment was no picnic either. I think most probably give up on having properly operating windows. It’s near impossible to get the car water tight. Good luck with yours.
Kit #361, arrived 10/2015, still in progress
818C highly modified, corvette suspension
Estimated completion summer 2023!
1989 turbo Supra 5 sp
2017 Tundra
Thanks Fman, I appreciate your comments! Definitely not his daily driver, I just don't think it will be waterproof or very reliable. This project has been about the journey and not the end result. We have had countless hours together over the last few years working away on it. If it was to blow up tomorrow it was easily worth the 18 odd thousand I have spent on it because it has been such a positive experience in both of our lives.
Nick has decided to go to college in New Mexico next fall, my alma mater. When he comes to visit us for breaks he can toodle around town in it, or autocross. He and I also have this goal of some day taking it to the Oregon Raceway and racing like a real race car!
Right now we are planning on Anthracite Gray Metallic with a flat matte satin finish.
So, we have the front end body fitted about as well as we can at this point. There is still some gaposis at the fender/A-pillar/door/hood interface but we will live with it for now. Driver side seems to have come together better than the passenger side.
The doors open and close nicely and I think the gaps are ok. I did use the slotted spring pin technique someone had recommended which will help when removing the doors multiple times.
I have the FFR upgrade wheels and am wondering if anybody used something different for tire size than the FFR recommended, 215/40/17 Front and
255/35/18 Rear . I have a feeling that front tire is going to rub. The OEM wheels and tires were rubbing while we were go-karting...
Mark,
We are using these wheels and the recommended tires, and they do not rub. They have the proper offset versus the OEM wheels, so as long as you have tucked away the coolant hoses, and followed the "rough alignment specs" for the UCA's it should be fine. Now...we are having rubbing problems with the left rear tire after final assembly...and paint. Still working on that one.
818 "S"pyder delivered 11/27/20, using 2007 Impreza 2.5l NA donor. Work mostly being done by my son Liam...body work and paint being done by dad (that's me)
MK3.1 #6583RD, built from 2008-2019, sold 11/2011
The fronts are particularly difficult as you need a relatively short tire < 24" tall. The rears are much more forgiving. I have used 215/40/17's and 225/40/17 Hoosier's on the front with no rubbing. On the rear I have used all the way up to 275/35/18's, although those are very tight!
No matter what tires you run you will need to use steering restrictors to limit the total lock to lock travel as the tire will rub on the inside splash shield at the limits of travel if not.
MK3.1 Roadster completed 2011
Thanks for the advice guys, I'll start looking for tires and steering rack restriction device.
These are track car observations that probably don't apply to a street driven car. Not sure where an autocross car fits in.
I have 215 in front with no rubbing issues other than lock to lock. I don't have rack spacers. I just know how far I can turn the wheel. The only time I get understeer is in the rain, so I see no reason to go wider because I try to avoid the rain in my open top car.
I have 255 in rear. With the FFR wheels, I needed 10mm of spacers to keep them from rubbing the lower control arms. I have Powerflex Black bushings. Rubbing was worst with the OEM bushings. I can't see going any wider without changing out the control arms. While I don't think wider front tries would improve the car's balance, I do thing wider rears would. Maybe someday I'll change out the control arms. Mostly because then I could try out some slicks that don't come in 255 sizes.
A note on using wheel spacers - make sure you can get at least 9.5 turns on the lug nuts.
A note on FFR wheels - they are a visual upgrade over OEM Subaru wheels, but not as strong. I have demoted my FFR wheels to street use only because while they still balance, they are easily bent pounding track curbs. A car destined for more than an occasional "gentle" track day needs wheels better suited for the track.
I've decided to take my best shot at power window modifications and replicate what FFRWRX did. Here's my initial mock up.
I'm making these out of 1-2/2" x 3/4" metal stick, I think its .08" thickness.
I have a ways to go...
It is a lot of work making the window frames, but to me at least, worth it. It makes for very nicely working windows that will seal and are fully supported anywhere along the travel. It will also make you realize just how bad the window design is. You can't have a window that goes up and down in tracks that has a different curve on the front and back. So even the added tracks are a bit of a compromise design.
Rick
Build page (The Bolton Build): https://thefactoryfiveforum.com/show...ton-Build-818C
Maybe look into a "tube roller". I used one to make this bike and it seems like it would work for your window frame project.
I’m gonna pop some popcorn! Keep us posted. I wouldn’t count on the roof curvature alone as a template. But a fully guided window mechanism is the only way to seal the side windows. I wish you luck.
2017 Tundra
Since I gave up on my 3D printed targa top and bought the FFR top, I have the same plan for windows. Thankfully I get to watch you do it first
The issue with trying to roll/bend channel is that if you bend it one way the side walls want to go out (excess material). So you hammer that back in and it bends another way. I thought of making some sort of rolling bender specifically for channel. It would have to be capable of rolling in various directions for the window frame. I thought it would be a huge effort for something that may or may not have worked.
Rick
My current plan was just pie wedge cutting them. Is that what you guys did?
Would it be useful to try using styrene U-channel and heat form it around the window edges? Once cooled, it should at least fit the window curvature in 2 dimensions. For example:
1/4 in. D x 3/8 in. W x 48 in. L Black Styrene Plastic U-Channel from Home Depot
If I had a coupe rather than a roadster, I’d try it before suggesting it.
Here's where I am after the weekend. This is challenging...
There is a significant difference in the curvature between the DS and PS glass. PS glass is more curved .
Here's where I am so far.
It slides pretty easily by hand...
Still have a ways to go but feeling pretty good about the DS side. Here is my problem.
That PS window has 1-1/4" more curvature than the DS. This may be hard to fit in the door. I reached out to FFR to see if I could purchase another window but they said they don't have any, I should have one custom made.
Is it possible to have a shop adjust the window using heat or something to flatten it out more? I am not sure if glass can warp. Now you have me nervous and wanting to measure mine. Maybe you could make a Lexan version? Lighter and easier to work with. If you have a window track, then the Lexan window should just ride and curve to that. Good luck to you. I am curious as to how you are going to solve this one.
So, a lot of life has gotten in the way since I last posted. My son, Nick, left for college last August. I toyed with the idea of selling the whole project which is what my brother suggested but I have persisted. I had read other builders say that the doors and power window made them want to give up on their 818C and I understand why. Here is what I have accomplished: First off the FFR driver side lock/handle is not workable. I spent way too much time trying to make it work. I bent it, made calipers, reversed it direction, read other posts. I got it to sort of work but it is absolute garbage. Here's a photo, the yellow arrow points to the problem part.
So I scrapped that mechanism and wired in the OEM keyless entry with this:
$17 on Amazon and has two remotes and a blinking indicator light. It works great. I kept the inside release lever but it is questionable and easy to "bend" accidentally. I added a "pull" wire that I can use to unlock the car if the battery is dead.
I also reinforced the upper sill with 1-1/2" aluminum square which I mounted with a combination of epoxy, rivets, and fiberglass
