Thanks Thanks:  24
Likes Likes:  39
Page 4 of 4 FirstFirst ... 234
Results 121 to 124 of 124
Thread: MJS Coupe Build
  1. #121
    Aug 2019
    Spokane, WA
    Thanks for the tip on the Coyote pedal placement. Kind of like what you did with the Wilwood pedal pad on that pedal, I'm going to try to adapt the Russ Thompson pedal pad (sourced from Breeze). Do you have any tips or pictures on how you attached the pedal pad?
  2. #122
    Dec 2018
    Hudsonville, MI
    The pedal pad I just attached with 4 stainless screws after trimming the lever back a bit more.
    Coupe Kit Delivered 11/10/23
  3. #123
    Dec 2018
    Hudsonville, MI
    Couldnt remember if I posted this before. Something Ive been using during wiring I found on the humvee sites. Great and actually reasonably cheap shrink sleeve printer made by Dymo, takes the standard labels but you can buy shrink sleeve cartridges. Makes great quick labeled yellow shrink sleeve and now I dont have to label all my wires with yellow tape!
    Word of caution. the 1/4 sleeve is really 1/8 as it relates to other shrink sleeve companies standards.
  4. #124
    Senior Member PNWTim's Avatar
    Nov 2020
    Damascus OR USA
    So this is funny. I have that exact label printer which I print wire labels on then use clear heatshrink over it. I didn't even know you could buy yellow heat shrink it will print directly to .
  5. Likes MSumners liked this post
