London Cobra Show
Thanks Thanks:  3
Page 2 of 2 FirstFirst 12
Results 41 to 52 of 52
Thread: Coupe Engine Bay Temperature
    Quote Originally Posted by Namrups View Post
    Dave, What weight Mobil 1 are you using?
    15W-50 Mobil 1
    The engine is a Ford Racing Boss block 302, forged internals, AFR heads. I do not know the bearing clearances.
    Gen III #17
    May 2021
    Fort Worth, Texas
    If it was a dino oil, I would be a little concerned about those temps, but for Mobil 1 synthetic, 260F to 290F is fine. You might want to consider switching to 5W-30W or 10W-30W. It may reduce the oil temperature. Higher viscocity oil does make the pump/engine work a bit harder.
    Senior Member Jphoenix's Avatar
    Apr 2020
    Bonney Lake, WA
    Quote Originally Posted by Dave Tabor View Post
    15W-50 Mobil 1
    Gen III #17
    https://performanceparts.ford.com/do...Z2363FT-RT.PDF
    Last page has clearances - this for a 363, but I suspect the 302 is the same. I suspect you can get the same pdf for your block part number. Ford recommends 10w30 or 10w40.
    Jim Phoenix
    Coupe-R delivered 8/10/2024
    289 USRRC, F5R1011063RD - delivered same day
    Coupe-R has a Ford Performance 363 mated to a TKX, 18084.
    Many details on my Coupe-R are different from a typical Coupe build because mine is not street legal, race only.
    289 has a BP 302 mated to a TKX 18084.
    "For a little more, you can do it yourself." - Ed Hollingsworth... 6-Pack forums
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    I have a Boss 427 that's been bored and stroked to 460. It is a street car and not a racer. I broke a valve at the end of last season and the cause was a lifter that gauled and froze in the open position. I was using Moble 1 5w-30 without an oil cooler. My builder is telling me to use 10W-30 with an oil cooler or 10W-40/20W-50 without a cooler.
    Scott Pregont
    My Albums
    Senior Member lewma's Avatar
    Jan 2018
    San Diego, CA
    Quote Originally Posted by lewma View Post
    Updates from todays run. Did about 120 miles this morning.
    Started with ambient bay temp of 70F. Within a couple of minutes, up to 115F when idling.
    ECT = engine coolant temp
    IAT = intake air temp ( via MAF sensor )
    BAY = engine bay temp. measured right in front of the firewall about 4" from the hood.
    When averaging 40mph on back roads, ECT 192F, IAT 75F, Bay 130F
    Sitting in traffic, lights. ECT 203F, IAT 80F, Bay 140F
    When averaging 75mph on the highway, ECT 194F, IAT 85F, Bay 120F
    For me, the engine bay only starts to cool when i'm doing 60mph+. Anything lower, the bay does not cool at all seems to follow engine temp only.
    Also discovered that my cooling fan stopped working sometime today too. Bringing it home was hitting 220F. Applied 12V to the fan. Nothing.
    Anyone have any recommendations for a RELIABLE fan setup ? This one only has 1K miles.
    Got the new fan installed. Also punched a hole through the forward scoop and the 2 smaller scoops in front of the windshield. More holes than a teabag now
    And..... it's raining. Perhaps tomorrow
    Build 2: Gen3 Coupe Complete Kit #309 Ordered 1/25/21, Delivered 6/9/21, CA SB100 Registered 8/27/24 - BluePrint GM 427 LS T56, IRS, AC, Power Steering. Album Here
    Senior Member JimStone's Avatar
    Nov 2022
    Niles, MI
    Lewma,
    Saw the vents on your Google photos album. Looks nice. Do you have the part numbers of the vents you used?
    Gen 3 Coupe #576 - "Project Deimos"
    Ordered: 2/14/2024
    Received: 5/24/2024
    Build Thread: https://thefactoryfiveforum.com/show...upe-has-landed!
    Jan 2018
    San Diego, CA
    Quote Originally Posted by JimStone View Post
    Lewma,
    Jim
    Watch out, they're expensive https://www.amazon.com/dp/B0D78J7FNW...sin_title&th=1
    Just took the car out for a quick run in-between rain showers. Didn't get on a highway but did a couple of miles on back roads 50-60mph. It was a little cooler this weekend than last but IAT was sitting high 70s. Ambient low 60s. Engine bay still heats up like an oven when the car is sitting still but starts to cool down when running. This time, with the front vent, then the 2 smaller vents open, at 55mph, the bay was down to 109F and was still dropping until I ran out of road. Previously it was holding at 130F.
    I'll try to get on a highway to see what happens at higher speeds.
    mark
  8. Thanks JimStone thanked for this post
  9. #48
    Feb 2018
    Half Moon Bay California
    Mark,
    Did you still have the hood to cowl seal during your testing?
  10. #49
    Jan 2018
    San Diego, CA
    Greg
    Yes. I wanted to change one variable at a time. Once I've been down the highway a couple of times to get an idea of what the vents are doing, ill remove a section of the seal to see if that also helps
    I'm considering drilling a couple of holes in the aluminum in front of the radiator to help when sitting stationary in traffic with the fan blowing
    Mark
  11. #50
    Jan 2018
    San Diego, CA
    Another 75miles on the car today, 50 of those highway miles. Sun was out, warmer than yesterday. At 65mph+ it seems like the vents really have an effect. They cool the bay from 140F down to 110F within a couple of minutes. At 85mph I think the lowest I saw was 107F with ECT around 192F. The vents seem to be less effective below 60mph.
    The flexalite fan seems to be a worthwhile upgrade. Quieter than the stock fan and cools the engine from 200F down to 194F very easily when sitting at lights.
    Next tests:
    - Remove a section of the hood seal under the windshield to see if that has any effect in cooling the bay
    - Drill a few 1.5" holes in the aluminum behind the fan to see if that can contribute to cooling the bay when sitting in traffic and the fan blowing. Did notice that my intake temps were up around 110F when sitting still.
    mark
  12. #51
    Mar 2021
    Ohio
    Jim
    mark
    Mark,
    Did you put 3 or 4 of the soffit vents in?
    Brent
  13. #52
    Jan 2018
    San Diego, CA
    Brent I put 1 4" soffit vent in the forward scoop. I planned on putting the 3" vents on the smaller scoops under the windshield but the vents were too deep. I have 3" holes under the vents which I plan on covering with mesh
    Mark
