London Cobra Show
Results 1 to 11 of 11
Thread: Need new horn
    Scowally's Avatar
    Jul 2017
    Wilson NC
    Need new horn
    My horn just gave out today (and I needed it!) for the person cutting through a parking lot and not looking.
    Anyway, my old horn just stopped working, and it really wasn’t very good anyway. I’m looking to do an upgrade and no, I do not want the train horn. If I wanted the train horn, I would’ve bought a locomotive.
    Any ideas for a good horn for Cobras that can be heard over our engines? The Hella airhorn looks like a good idea but it looks quite complicated for wiring.
    Would love to hear your thoughts if you’ve had similar issues and what you used for horns
    Scott
    Mk III, 331, Edelbrock dual quad, paint and body work by Whitby
    Dec 2021
    Flower Mound TX
    The horns that came with my MKIV kit are plenty loud. Not train horn loud but louder than a typical OEM car or truck which is what you need with these cars. You might check with Factory Five about buying a set.
    Senior Member MB750's Avatar
    Feb 2022
    Tampa, FL
    Quote Originally Posted by Scowally View Post
    Scott
    Go to Auto Zone/Advance Auto/O'Reillys/Napa and buy two of those disc horns. One is high-tone, the other is low-tone. Use them both. That's what the Mk4 has.
    Or, there's those motorcycle specific ones that are plenty loud as well, but they usually require a relay.
    Matt
    My build thread here
    Quote Originally Posted by MB750 View Post
    The Ron Francis harness already has a horn relay.
    O'Fallon, MO
    Salvage yard……..Mustang horn.
    All horns use a relay
    Senior Member TTimmy's Avatar
    Sep 2021
    Emmaus, PA
    I tried a Bosch disk horn but it sounded like an import. I landed on these; I got a high and low tone.
    FIAMM 72102 Freeway Blaster HIGH... https://www.amazon.com/dp/B000FKKOK6...p_mob_ap_share
    Build 1: Type 65 Coupe
    - Album: Coupe Album
    - Delivered: February 24, 2022, Legal: April 20, 2024, Complete: TBD
    Build 2: Mk3 Roadster
    (Acquired as a partially started build)
    - Build Thread: TTimmy’s MK3 Basket Case Build Thread - Album: Mk3 Album
    - Originally Delivered: 2004, Acquired by me: August 2024
    Senior Member Nigel Allen's Avatar
    South Australia
    Many European cars have twin horns that are loud and have a good note. Hit the salvage yard.
    Gen1 Coyote / TKO600 / IRS
    These $25 horns from HF aren't bad. Used them a couple times. https://www.harborfreight.com/automo...orn-58807.html
    Senior Member john42's Avatar
    Aug 2020
    Hollis, NH
    I have a Bad Boy horn. Has a nice (loud) Euro Sports car sound. Not overly loud but certainly a bit louder then the FF horn.
    https://a.co/d/eydoTNW
    MK3 Challenge Car, Boss 347, Sniper 2 EFI
    Feb 2024
    Got a Hella Ferrari replica horn. Cheap, loud, easy to install, and cool as hell.
    I put Hella tri-air horns in both of my builds. Here’s a demo:
    I made the brackets myself. You should be able to find them in my 15th anniversary build thread linked below.
