Thread: Driver Side footbox mod
    Atlanta, GA
    Hello all, can anyone point me to a vendor who makes the Drivers Side footbox mod. I found the vendor sometime ago, however, I have lost the contact info. The mod is for a dead pedal bump out on the Driver Side. I believe the piece sold for $28. HELP!!!
    Moreno Valley CA
    I believe you are looking for Darkwater Customshttp://www.darkwatercustoms.com/cart...=0&sort=normal
    Mk3.1 delivered June 2011, 96 Mustang donor, 98 Cobra 4.6 DOHC motor, Hydroboost, PS, ABS, 3 link, A/C, footbox/trunk/batterybox/SAI/Bumpsteer/vents mods.
    Still a work in progress.
    Senior Member MPTech's Avatar
    St. Louis, MO
    This is not an mk4, correct? I this mod is mk3.1 and earlier only.
    Atlanta, GA
    Yes, that is the one. Thank you.
    Atlanta, GA
    I have a Mk iv. Is that a problem?
    Quote Originally Posted by ksamson View Post
    The left side of the driver's footbox is already pushed out as far as possible on the Mk4. No room for a bumpout; it would collide with the body.
    If you're interested here is a discussion on footbox mods, some of it applicable to the Mk4:
    http://thefactoryfiveforum.com/showt...hlight=footbox
