When I was checking the mounting for the gas cap The unit came apart. The outer ring that attaches to the body came away from the center. It was glued together. I think someone forgot to weld it. Here is the fix I came up with. I ended up using 6-32 S/S screws and washers to hold both together. I know it will not separate now.
