Thread: unvented brake reservoir
    Dec 2014
    Paris Arkansas
    Has anyone had issues with the wilwood reservoir as mine has no vent
    2bking's Avatar
    Garland, Texas
    I have the FFR reservoir and it isn't vented either. When I inquired about the issue, the solution offered was to leave the cap loose and/or remove the sealing O-ring.
    King
    Raleigh NC, OIB NC
    Drilled a small hole in mine
    Kevin
    MKIV #8234
    Senior Member rmiller64's Avatar
    Ferndale, WA
    Kevin has me thinking about a small (tiny) hole in the top of the cap also
    Rick
    #8442 MK4 Complete kit, 331 Stroker, T5, 3.73 Posi 3-Link, 15", Goodyear Billboards
    Order 8/22/14 Del 11/7/14 First Start 3/9/15 Go Cart 3/14/15 Paint 2/25/16
    http://thefactoryfiveforum.com/showt...MK4-8442-Build
    Richmond, Texas
    The instructors at the build school said to simply remove the "O" rings from the reservoir. That's all I did and the brakes work fine. IMO I would rather do that then drill a hole in the cap.
    Sure makes one wonder about buying from Wilwood doesn't it?
    Raleigh NC, OIB NC
    Yes it does.
    Kevin
    MKIV #8234
    Raleigh NC, OIB NC
    Contacted CNC about their reservoirs & they have a pin hole vent in the cap, so will stay with what I have.
    Kevin
    MKIV #8234
