David,
Thanks so much for posting the links on the "how to". I too am a user of SharkHide, but have struggled getting a good clear application ...now I know what I was doing wrong.
David,
I'm waiting for a DMV issue to work itself out but I couldn't wait any longer for...
GRADUATION!
http://thefactoryfiveforum.com/showt...ot-TROJAN-quot
Quick update: STILL waiting for Sacramento to ship out a duplicate certificate of sequence! I'm really cutting it too close for making the 1/26 BAR appointment!
The duplicate Certificate Of Sequence has not arrived and the BAR appointment has been moved to 2/4/2016.
Grrr...
I feel your pain. I am still waiting for the title, registration, and plate for a trailer I bought on 11/15 in Northern California. Nothing yet - arggg....
Kevin
MKIV, IRS/TruTrack/3.55s, Coyote, TKO600, Wilwoods
Delivered: 1/6/2012
First Start: 1/19/2014
First Go-Kart: 2/1/2014
Graduation: 1/4/2015
Graduation Thread
Well the Certificate of Sequence FINALLY CAME! My 3rd attempt at a BAR appointment was yesterday morning so I'll call this AM to set up yet another.
I've moved TROJAN back home so that I can get some work done on ol' 5369. TROJAN is a people MAGNET on the road! I can't wait until this reg. process is over so my bro and I can put some miles on!
Hi David, congratulation for your final registration of the Trojan! Wish you and your bro always a safe drive. Hope to catch up one day,
Georg
Georg!
GREAT to hear from you! I hope all is well and although our "arrangement" didn't work out, I am working on getting my MKIII ready to sell so I can move on to the next big build! It just won't be a 20th anniversary car...
http://thefactoryfiveforum.com/showt...ep-quot-thread
I've set up another BAR appointment for this Tuesday (2/16) and then we will be ready for plates!
I hope you find a way to the 'States soon; would love to hoist a few beverages with you. Keep the dream alive brother!
No matter how hard I tried, San Clemente still did not believe I needed a sequence number for SMOG. I had to get another appointment just to go in there and force them to call the BAR to confirm. Sounds like I'll need to bug Sacramento as well to actually get it processed. Oh well, still getting the top end re assembled while I wait for the mediocre efforts of the state to get something done. Congrats Chewie.
Raising the bar
I went to the KC world of Wheels show yesterday. There was a nice collection of Cobra replicas in "the Snake Pit" several FF's and a couple other brands as well.
The one thing that they all had in common was the unfinished look inside the nose of the car. The piece you made for the anni coupe has raised the bar and I will
never be able to look at one again without thinking this car needs one of those to look finished.
Well done
DB
DB,
Thanks man! I'm currently in the middle of making one for my MKIII:
...and yes I will be making more to sell as a vendor.
Today's the day! We have a 7am appointment with the BAR referee. If all goes well it will be the last stop before getting plates from the DMV.
FAILED.
What's wrong with this picture?
Hint:
Did they want the gas vapors from the fuel tank to be routed into the intake manifold?
Dale
Dave-
They didn't like the rumble seat? Looks like he can be pretty comfortable back there...
You are missing the hose from the air cleaner to a breather cap.
Doug
Built FFR5196 MKII in 2003, 427w
Building FFR0058HR, Edlebrock 347-AOD
What Doug said. They don't want the crankcase to breathe to atmosphere.
You forgot the PCV valve!??? Rookie!! LOL. Wait to you see the POS I"m rigging up for my appointment!! Looks like something Clark Griswold or Willy Wonka would think up.
I had another problem show up while driving to and from the appointment. When applying the brakes at a very low speed, say 5 mph, there is an alarming loud moan and high frequency shudder coming from the front brakes. I believe anti-moan brackets are used on some production cars for this. I've got larger PBR front brakes that were supplied with the kit. What do you think it could be?
Have you taken the time to bed the brakes?
Doug
I believe factory anti-moan brackets are only available for the rear brakes. They bolt to the back of the main caliper bracket and mount to the axle tube with a u-bolt. If the sound is coming from the front brakes, something else is happening. I had PBR's on my Mk3 and never heard anything from them. Something loose? Right pads? There are insulation pads or compound available for the pads. But maybe they just need to break in as mentioned.
Dave-
They make an anti-moan compound or disc brake compound (or similar), which I think is what Paul is referring to. It is essentially an adhesive that helps seal the brake pads to the caliper so it doesn't cause the vibration that can happen. Any auto parts store or even Walmart carries it. I think I would start with that, and since you have to get at the brakes to do it, a visual inspection might reveal something else that may have been overlooked. Good luck!
I've only lightly bedded the brakes (several full force stops from 30-0). I obviously need to do a visual inspection but I'll definitely try bedding the brakes better and then try that anti-moan compound if it persists.
Gotta say, it was pretty un-nerving the first time I felt it. It felt like the brakes refused to grab.
Mike Forte came through once again and a new breather and air cleaner elbow are on their way . I'll document how that goes together before the next BAR appointment on 2/24, a week from today.
Thanks guys,
I had the same shudder and moan when I last replaced the brakes on my daily driver. New ceramic pads and new rotors. I thought I had bed them in well enough. I took it back out on the highway and laid on the brakes a few times from 60-ish. I made sure no one was behind me . Did that a few times and haven't heard or felt anything since.
I'll try to re-bed the brakes today. I will be bringing the car to the shop to install the new breather and air hose I got from Mike Forte this afternoon. The part that attaches to the air cleaner is a 90 degree port and I have to pick up some tubing from the local hose company. The new BAR appointment is tomorrow at 7AM. Here's hoping this is FINALLY the last step before registration!
Dave,
Make sure that the hose you get is fuel rated, the BAR up here started failing builds due to people using any hose that would fit and NOT fuel rated.
Doug
__________________________
Since my local NAPA only carries emissions compliant fuel hose I forgot to mention that. I just did not want you to buy a vacuum or heater hose and fail again. Frank, thanks for the clarification.
Doug
Dave-
I hope it goes well in the morning! I look forward to hearing that it is all good to go.
After the car failed the first BAR exam I contacted Mike Forte to get the proper fittings. He sent me a pic of the two options he had in stock for sealed breathers:
I went with the chrome (duh) and he also sent out an air filter right angle fitting to make sure the hose wouldn't kink. He made sure to tell me to use rivets instead of the screws as the screws have a reputation for loosening and then being ingested by the engine! Once I got the package on Monday night I compared the fitting with what the air breather had and went to NAPA to pick up 2 feet of 1/2" ID PCV/ EEC hose. It came out of a box and had a nice curve already built in so I decided to do without the right angle fitting. Once that was in the car was ready to go.
This AM we were up before dawn to drive to the 7AM appointment:
I drove separately so that I could split after to go to work. As Phil exited the freeway I noticed he was having some trouble but he managed to make it to the inspection station. He parked it in front and since we were a little early we headed out to get a quick bite before inspection. Once we got back I went to move the car to the garage and found that it wouldn't shift! I quick call to Mike Forte confirmed what I was thinking: a limiting bolt on the shifter had probably backed out and was preventing the shifter from working. Unfortunately the shifter boot was installed and would have to be cut out to get to the limiting bolts. That stupid trim ring had taken over an HOUR to install! Grrr! So I borrowed a dull packing knife from the inspector and hacked out the boot. Sure enough, the bolt HAD backed out:
OK so now I'll have to spend another hour putting in a new boot but guess what?!?!
WE PASSED!!
I even got the inspector to put the sticker of the 2x2 frame under the steering wheel instead of on the firewall! YES!
That drama over, I headed off to work and Phil is on his way to the DMV to GET PLATES!! WOOHOO!!!
After a week or so to give the paperwork a chance to be integrated into the DMV system we'll go to AAA and get the plates switched to TROJAN and order another set in classic black and yellow.
We're over the hump and LEGAL!
