61
403
Very Nice work and a unique approach! Are the exhausts going to exit thru the humps? Now that's novel! (You may be breathing fumes though).
I'd love to put an H6 in an R and race it, if only someone could come up with a dry sump solution for the 30 or 36.
Owner: Colonel Red Racing
eBAy Store:
http://stores.ebay.com/colonelredracing
818R ICSCC SPM
Originally Posted by
Scargo
Purely for racing? Many of the tracks I frequent for track days, have sound limits. Any thoughts about mufflers?
Purely racing and no sound limits at the tracks I go to.
flynntuna
Looking great! If you get a chance, could you get a picture of the headers a little further back, with the perspective of say from the firewall to the axles?
Not sure what your looking for? Can you explain it differently, maybe I'm being dense.
Sgt.Gator
They will exit through the Mechie hump vents, so you won't see the pipes. Talked about this in a previous posts and the consensus is that the R does not suffer from the back flow issue that the S does with its high windshield. I'll know for sure next spring!
Sgt.Gator
I'm hoping I don't need a DS. The EZ36 holds 8.2 quarts of oil in stock trim. With my external cooler and Accusump I'm at 10 quarts! I have equipped pressure sensors before and after the Accusump so I can monitor the pressures and know if the oil pickup is sucking air BEFORE the engine loses oil pressure while the Accusump if supplementing the prerssure . I won't know for sure until I can get some data logs and check the oil pressure differentials. I do have a DS system planned out if I see any pressure loss before the Accusump.
Hobby Racer
Are you concerned about the air pressure being greater outside the vents such that it may force the exhaust gases into the engine bay? Or are you going to make some sort of exhaust shroud? Also, wouldn't the exhaust pretty much cook those vents and the fiberglass they're attached to?
STiPWRD
I plan to seal off the exhaust to the bottom of the vents with an aluminum box. The air rushing over the vents should draw the exhaust out as well. Not sure about the heat cooking the aluminum, guess I'll find out
