0
0
I guess I won't know until I try to actually start the car, but I was assuming that the coil was powered by the EFI harness connections through the distributor. The EZ-EFI 2.0 harness actually shows this powered connection.
Of course, the pictured schematic is different than the one on the provided thumb drive. If it doesn't fire, I will pull another wire. I'll put a volt meter on that coil + post today and see if I have power there with the key on.
