0
I used the mid shift on the TKO 600 with my Coyote and yes you do need to cut the diagonal brace across the top of the tunnel. I have long arms so it is more comfortable for me but it does put the shift ball about 4 1/2" from the dash in 1st gear. I ended up using a shift lever that lays back about an inch.
