0
0
Originally Posted by
narly1
It's always been my understanding that paints don't adhere well, if at all to silicone.
Shouldn't it be paint first then silicone?
Earl
Paint does not do well with Silicone. The surface tension of the silicone will cause most paints to bead up and not wet out the surface. Given that the Lizard Skin will most likely be covered with carpet it should not be an issue. No one will see it and the silicone itself will deaden the sound and insulate against the heat as well as or better than the Lizard Skin we are trying to cover it with.
