Sounds like an angry bee. Does this engine have variable cam timing? I do not see a surge as I have seen on my J-V6.
What RPM are you comfortable with?
jim
jim
It does have variable valve timing on the intake but we did not even try to tune that yet, so it's running at 0 degrees cam advance. There will be some more power to be had there as well!
The factory redline is 7100 rpm so I'm going to stick with that. I did remove the balance shafts and install the better K20A oil pump that is rated up to 8500 rpm but since I'm using the stock valves springs I do not want to push my luck by going any higher than the factory redline.
MK3.1 Roadster completed 2011
