Results 1 to 40 of 64
Thread: Must Have Kit Mods...?
    Senior Member cv2065's Avatar
    Dec 2017
    I looked around but didn't see a thread like this. Out of all the great build threads on the forum, I thought it would be cool to put a 'must have' or 'necessary' mods thread together that people have done to their kits over the years, which would serve as a resource for new and existing owners.
    Senior Member Clover's Avatar
    Colorado
    Good idea, I am also interested in this and have been searching around the forum finding bits hear and there. I think it would be helpful to contain many ideas in one space and have not yet come across the place myself, though I figured it was out there somewhere. Some of the items I have come across are listed below but I am not an expert on any of this. These are not must haves but things that I see fairly commonly.
    Cheap Amazon Seat Heaters
    Hawk HPS brake pads
    QA1 Coilovers
    Heat/sound insolation along the lines of Lizard Skin
    Expanded foot box
    Nicer Carpet
    Cobra or 13" 15+ IRS larger brakes
    Trunk mod for a little extra space
    Grand Rapids, MI
    My vote, Russ Thompson turn signal.
    Santa Clarita, CA.
    Firewall Forward and Battery Box from FfMetal
    Competition Dash - Not a single clue why FFR does not offer the Comp dash for the Mk4 S/C (semi competition) Roadster.
    Turn Signal and Accelerator Pedal from Russ Thompson
    Mechanical Throttle Kit from Fortes Parts
    F5R #7841: Anniversary Edition MK4, Ford Racing 427, Edelbrock EFI, Gas-N Pipes, Stainless Headers, TKO600, 3.31 Moser 3-Link, 17" Halibrands
    Here are my minimum mods:
    1 - Any battery relocation kit.
    2 - Separate brake reservoirs.
    3 - Breeze radiator shroud.
    4 - Boig Cool Tube kit.
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
  6. Likes timmil liked this post
    These should keep you busy. Some of the results from Google. Best and quickest way to search on this (and the other) forum. From the Google prompt, enter exactly (without the quotes) "site:http://thefactoryfiveforum.com /kit mods". Replace "kit mods" with whatever search term you want for other results.
    https://thefactoryfiveforum.com/show...-modifications
    https://thefactoryfiveforum.com/show...s-Let-s-see-em
    https://thefactoryfiveforum.com/show...ghly-recommend
    I will add
    Breeze front battery mount
    power brakes
    power steering
    replicaparts nose aluminum
    FFR supplied vinyl dash
    Jax Beach, FL
    A real "must do" list is almost non-existent with a MKIV. But there are some nice to do items, which vary on personal taste and what you are going to do with the car.
    Here is my list:
    Russ Thompson turn signal and gas pedal.
    Power steering
    FFMetals battery box (weight in the rear where these cars need it)
    Wilwood brakes - not must have for a cruiser, but I wouldn't build any other way.
    Boig cooling tubes - very much a must have.
    Fan shroud.
    Trunk mod. I didn't do it during the build. But, I did it later so I could get my helmet in the trunk.
    Heater / heated seats / wipers.
  10. #9
    Aug 2017
    Southern WV
    Front and rear bumper grommets from finish line
  11. #10
    Lost Wages, Nevada
    Having a MKII, I've made quite a few "mods" . . . being a MKII, I rounded the cockpit edges (not required anymore on the newer models) as the first mod. Did the "Drop-Butt" mod for looks (also not required on the newer models). After that, everything was mostly for comfort - quieted the pipes a bit, installed a glove box [for the wife], swapped to newer MKIV seats, installed fresh air vents, added power outlets in various spots around the car to facilitate cell phones, GPS, Etc., moved the hand brake to the left side of the drivers seat (the Fiero Mod). I've added sun visors, wind wings and relocated the rear view mirror to the top of the windshield (for better visibility), extended both the side mirrors farther outbound for the same reason. Extended the PS footbox and added a slope to the leading edge to get rid of my heel getting caught every time I exit the car.
    Mechanical mods consist of: lower radiator support rod, relocation of battery to rear of drivers side wheel well, relocate fuse block to a drop-down panel, bump-steer kit (after determining that it was needed) , bigger brakes all around (13"F, 11.65"R), Breeze LCA bushing sleeves, Breeze Rack bushings, needle bearings on the spring mounts (allows springs to rotate freely).
    Next on the list of "It'll never be done" mods is: front rad opening nose aluminum, upgrade shocks to something newer then my old Pro shocks, sway bars, 3-link brace (both parts) and a Bimini top for shade.
    Doc
  12. #11
    Jun 2015
    Fairfax Station VA
    As Dave said, the mod you simply MUST do is multiple brake reservoirs. That way if your front/rear brake hydraulics fail, the rear/front brake hydraulics remain unaffected.
    I will also add that the Russ Thompson gas pedal coupled to a mechanical linkage is SUPER nice. And since no one has yet mentioned a hydraulic clutch, I will .
    MK IV Roadster #8631
  13. #12
    Colorado
    Here in Colorado, we all had to install secret compartments for our drugs in the past. However, that was made legal a few years back and we don't need the secret copayments anymore.
  14. #13
    These cars are never "complete" so I focused on the modifications that would be extremely difficult to do later, after built.
    - Driver/Passenger footwell expansion.
    - Trunk expansion
    - Battery Box
    - Hood hinges, pins are such a pain!
    - FFR Spindles, don't screw around w/ donors or kits.
    - Modified brake pedal, few do it ... But my manual brakes feel like power assist!
  15. #14
    Senior Member skidd's Avatar
    Jan 2016
    SA-TX
    Quote Originally Posted by GFX2043mtu View Post
    I vote, my turn signal system
    https://thefactoryfiveforum.com/show...hlight=Arduino
    My list though...
    - front battery
    - 5 lug axles for better wheel & tires choices
    - top of tunnel parking brake
    - hood hinges
    2016 MK4 | '99 Explorer 5.0 | E303&600cfm carb | T5z + 3.55 | 3-link | SN95 | PB/PS | FR500 17" 315&275 |
  16. #15
    doddmoore's Avatar
    Mar 2018
    Jackson, MS
    Not sure how to follow a thread other than commenting so...following.
  17. #16
    Quote Originally Posted by doddmoore View Post
    If you scroll to the top of the thread, just above the first post you will see a menu item "Thread Tools". Click on it and select "Subscribe to this Thread ...".
    Legal: 1/30/2020
  18. #17
    doddmoore's Avatar
    Mar 2018
    Jackson, MS
    Quote Originally Posted by papa View Post
    if you scroll to the top of the thread, just above the first post you will see a menu item "thread tools". Click on it and select "subscribe to this thread ...".
    thanks!
  19. #18
    Must have mods to me means safety... one of the biggest is separate brake reservoirs. This could save your life. Every car should have this.
    Next I would move the battery for shorter cables and easier access. The Breeze kit is really nice for this.
    While I made the plan for my car, and while building, I tried to think Safety, Reliability, Convenience, Fun. So I have quite a few mods to meet these parameters. But the 2 above would be my biggies.
  20. #19
    Senior Member stack's Avatar
    Macedon, NY
    I get these items for every build
    FFMetal Battery Box
    Russ Thompson trun signal
    Mike Everson Under dash aluminum
    Mike Everson aluminum dash trim bezel for the russ thompson turn signal
    breeze fan shroud
    Herb's Door panels
    Mike Forte mechanical throttle linkage if not doing a coyote
    hope this helps
    stack
    FFR MKI Roadster FFR2202K Built in 2000 sold
    FFR Hot Rod #39 under construction
  21. #20
    Good info... Thanks
  22. #21
    Many great mods mentioned already. In addition;
    - If you're installing a Coyote, you need to invest in a set of 4x1x4 headers from Stainless Header (Thanks again Slider for your design on these headers)
    - Also, if you're using a Coyote, you should invest in a mod program for the ECU. More commonly known as a tune.
    - Herb makes some very nice door panels that others have copied. You know its a compliment when someone uses your ideas.
    - The snapless tonneau cover from Kay and Phil works very well.
    - Marine style cup holders in the transmission cover.
    - Battery cut off switch.
    - Drive shaft safety hoop.
    - E brake cable routing mod.
  23. #22
    Mar 2017
    columbus ohio
    Here are my preferences:
    Must haves----
    Front battery Box
    Russ Thompson Turn Signals
    Thermal/Sound insulation--Pick your brand preference
    Heated seats
    Production car quality door latches--We are developing a kit for this and should have it available in about a month
    Inner door panels
    Power Steering
    like to haves---
    Heat/Defrost/AC
    Push button controls with waterproof switches
    Traction control
    Production Car quality interior
    Rag top that doesn't look like a wart and can be quickly depolyed
    Ohio
    Here's a few
    Any battery relocating box
    Recessed floor in trunk
    Breeze storage cubby behind the seats and into the forward trunk area
    Tangent blind roll bar attachment
    Heated seats
    Russ Thompson turn signal, accel pedal and dead pedal
    Breeze upper and lower radiator mounts, shrouds and stainless radiator tubes
    Replica parts radiator front shroud, under dash panel, turn signal bezel and shoulder belt trim
    Whitby power brakes
    Wilwood brakes
    Power steering
    LED lighting
    Panic handles (passengers are always grabbing them. Don't know why.)
    Console. Very handy
    Triple reservoir setup for brakes and hydraulic clutch
    Mechanical throttle linkage
    Wheel well liners
    Larger coolant recovery tank
    Different side mirrors
    Whitby' s windshield reinforcement pieces
    XPEL protection in critical areas
    Finish line bumper grommets and emblems (I especially like their steering wheel emblem)
    Fire extinguisher
    Custom shifter knob
    Trunk lighting
    Wipers
    Insulation cockpit and trunk
    Sill trim
    Dash support ( really strengthens up the dash along with the underdash panel )
    Door panels
    etc etc etc the list can go on and on. That's the fun of these cars. You can do whatever YOU want.
    JRL16
  25. #24
    1. 383 Small Block Dart (Chevy Style Engine) 9.7-1 Pump Gas Friendly Compression Ratio!
    2. Eagle Internally Balanced Rotating Assembly With 6" H-Beam Rods With Floating Forged Flat Tops.
    3. Dart Iron Eagle 215 CC Heads with 2.05 Intake & 1.60 Exhaust Valves.
    4. Harland Sharp Roller Rockers & Other Go Fast Goodies.
    5. Comp Cam Extreme Energy 288 Hydraulic Roller Tappet Cam
    6. Edelbrock AVS 800 Feeding A Weiand 7530 Team G Single Plane Manifold.
    7. Schoenfeld IMCA Modified Headers & They Really, Really Fit, But Stuff Had To Move A Bit!
    8. New Old Stock Corvette ZF 6-Speed Transmission With Hydraulic Clutch. (.75 5th & .50 6th Gear Over Drives)
    9. Standard Front End Set Up With Mustang Brakes.
    10. Standard 3 Link Moser TSD 500 (Dana 44 Rear) With 3.73 Gears & Explorer Brakes.
    11. The wheelbase has been shortened by .875" to better center the rear wheels within the wheel arches and improve pinion angle adjustment.
    12. Moved the fuse block to the passenger side of the car.
    13. Marine Stereo with 4 speakers.
    14. Passenger Side Custom Heater
    15. Drivers & Passenger Side Foot Box Vents With Blowers
    16. Lowered Dual Roll Bars.
    17. 3/4" front sway bar.
    18. Breeze Seat Brackets
    19. Removable Steering Wheel
    20. MSD Circle Track Adjustable HEI Rev Limiter
    21. Custom Lower Radiator Mount Using Breeze Fan Shroud To Support The Radiator.
    22. Removable Trans Tunnel Top
    23. Removable Slave Cylinder Panel / Hatch
  26. #25
    doddmoore's Avatar
    Mar 2018
    Jackson, MS
    I have a local car upholsterer who is going to do my interior but he was asking about door cards. I am a LONG way off from needing them but I like to plan. What are the best options out there?
  27. #26
    Cobra Herb!
    Mine are standard pockets in leather.
    Legal: 1/30/2020
  28. #27
    doddmoore's Avatar
    Mar 2018
    Jackson, MS
    Cobra Herb!
    JUST checked out his site and he says he can use my leather. That is fantastic. It feels forever away, but I've already upped my delivery date once. We shall see.
  29. #28
    His turn around time is pretty quick and he has done a few sales in the last year. I got mine during his 2017 Father's Day sale. If you don't need them right away, you may want to hold off until his next sale. They can be installed at any time and aren't needed during the build.
    Legal: 1/30/2020
  30. #29
    I had him do mine in my leather during his most recent sale. Had the panels back in less than 2 weeks, and he had a bunch to do. Just let him know what you want to do and he'll tell ya how many pieces he needs and what size. I wont be installing mine for another few months... but they look great!!
  31. #30
    Senior Member walt mckenna's Avatar
    Perkasie, PA
    Re-contour the top of the doors (while in for body work and paint) to give 1.5 more inches of shoulder room (3 inches more cockpit space). Provides a roomy feel with much more comfort and looks like it was designed that way.
    Mark IV -- 04 Mach1 Donor -- 4.6 DOHC -- TKO 600 -- 3:55 Gears -- 3 Link - Hydroboost PS & PB -- 13" PBR's Front & 11.65's Rear -- Cuesta Wiring -- Thompson Signals -- FFR Radiator, heater, wipers, and catalytic converters -- Metco DS safety loop -- Forte 7/8" front bar -- VPM 3/4" rear bar -- Champ road race pan -- Corbeau A4 Seats -- Nitto NT-05's on 17 x 9's.
  32. #31
    doddmoore's Avatar
    Mar 2018
    Jackson, MS
    Quote Originally Posted by Boydster View Post
    Wow those do look great. Similar color to what I'm going for on the interior too. I saw your Gokart video the other day Boyd. Sounds soooooo good.
  33. #32
    doddmoore's Avatar
    Mar 2018
    Jackson, MS
    I will do exactly that. Putting it on the calendar now
  34. #33
    Thanks. I had the waterproof cover on the GoPro, so it didnt even really get the sound too well. It sounds much better in person.
    I got my leather from The Leather Hide Store. Called Grey Paradise. Bought 1 full hide and it was more than enough. Allowed for 1 full screwup on the dash, then did the dash, switch panel, both door panels and the center console. Still have some left over to maybe make some more pockets, detail stuff, etc.
    Secret side note... going to do the body stripes in the same color grey, only metallic...
  35. #34
    24. Forgot I that I bought a pair of killer door panels from Sir Gumball and at a fantastic price I must add.
  36. #35
    Santa Clarita, CA.
    Herb's Door Panels in Leather.
    Did I also mention, Competition Dash, also in the same leather.
  37. #36
    Apr 2018
    Agreed, the Herb door panels do look very nice installed.
    Kudos on the the thread --> cv2065
  38. #37
    Jan 2018
    Sammamish, WA
    My 2 cents + questions
    As I read thru all the build threads, I compiled my list of goodies I wanted to get as well:
    1. Breeze: Battery Front & Lower radiator support kit & Fan Shroud
    http://www.breezeautomotive.com/deta...518&cat_id=25#
    http://www.breezeautomotive.com/deta...=494&cat_id=17
    http://www.breezeautomotive.com/deta...p?prod_id=1117
    ? Question: Is the upper support required/good idea as well?
    (maybe the Cockpit bulkhead trunk shelf too)
    http://www.breezeautomotive.com/details.php?prod_id=861
    2. Replica parts: Radiator Panel, trunk support
    http://www.replicaparts.com/Roadster...nel%20page.htm
    http://www.replicaparts.com/new%20st...kit%20page.htm
    3. Russ T: Trunk Kit (is the hoop conversion kit listed the right one to order, I have this pic and think it is called the drop box but cant find on his website)
    4. FFMetal: Thicker firewall
    http://www.ffmetal.com/
    ? Question: As for the Triple CNC Reservoir Setup, I had planned to get from Forte's, but his site redesign made my link break. Anyone have a link to proper triple reservoirs?
    Then there is the choice between a couple brands:
    1. Koolmat from Breeze (pre-cut but pricey) vs Thermo-Tec and Jazzman's cardboard template method
    2. Radiator pipes for Coyote from Boig or Breeze
    Thx
    -Brian
    MK4 Complete Kit #9311 - Coyote, TKO600, IRS
    Ordered: 1/23/18 | Production Complete: 3/6/18 | Delivery: 3/30/18
    Build thread
  39. #38
    Kirkland, WA
    Call or email Russ for the drop trunk kit - I just did. It is NOT the Mk3 hoop conversion kit, that was something else not relevant to the Mk4.
    Mk4 #8861 Complete kit. Delivered: 27 Apr 2016, currently a roller.
    Gen-2 Coyote, clutch, TKO600, midshift, and solid axle from Forte. Many pieces from Breeze and Replicarparts.
  40. #39
    Member Kpt112's Avatar
    Bucks County PA
  41. #40
    Oct 2017
    Williamsport, IN
    After I ordered my kit, I called Breeze with my specs. He emailed me a list of "improvements" that would fit with my particular build and an explanation on each of why. Other than that, I ordered the drop trunk and turn signal from Russ Thompson, full LED lights from Watson's, and roll bar wedge kit from Tangent. This is not the cheapest way to go I'm sure but they are all forum sponsors and know what works.
    MkIV complete kit #9259, Coyote, TKO600, IRS, Wilwoods x 4, many parts from Breeze, Forte, Russ's Garage and North Racecars
    17" Bullit style wheels, custom Kirkey seats, mid shift conversion, drop trunk, KRC power steering, Forte Hyd. clutch and slave, manual brakes
    overall build plan: build it to drive, not polish and black it out wherever possible, paint will be some shade of dark cherry
