Hey guys,
I picked up a '66 mustang from a friend that was 4/5 the way through a resto-mod rebuild. It has a new 302 in it and we are going for first start(!)'
We have a couple of issues related to wiring and possibly the fuel pump.
First, can you verify that I have routed the fuel lines correctly through the mechanical fuel pump? there is a hole above the input (as I routed it). Here's a pic:
Secondly, we went for first start and when we turn the key to the start position, nothing happens. I we reverse the wires on the front of the solenoid(red with gray, brown), the engine cranks. We are using a 1 wire alt and starter so the wiring is a little non standard.
Any ideas greatly appreciated! Here's a pic of the solenoid:
Help!
