Results 1 to 10 of 10
Thread: Trimming the Quick Time Bellhousing
    Senior Member Alphamacaroon's Avatar
    Jan 2019
    Richland, WA
    Hello all, I'm getting ready to trim the bottom of my QT bellhousing (Coyote -> T56 Magnum) similar to edwardb's build— I agree it hangs down way too far for comfort.
    Any tips or tricks on how to cut it? I will be attempting to do it while mounted on the car. I assume a metal cutoff wheel is probably the best tool for the job?
    I used a metal cutoff wheel on mine. Then cleaned and straightened using a stationery disk sander and touched up with some Eastwood black chassis paint. But I had it off the car at the time. In place would be a little harder, but still manageable. You could even use a reinforced cut-off wheel in a Dremel. Just be prepared to go through a couple disks. It's pretty tough and thick material.
    Jan 2019
    Richland, WA
    Thanks again edwardb. Yeah it looks like it’s going to take some time to cut through it.
    Feb 2018
    Frisco, TX
    I trimmed mine before I put the motor in, but agree it should be doable from under the vehicle. I used my angle grinder with a cutting disc to make the cut. I then cleaned up the edge with a flap disc and then touched up the bare edge with some POR-15 I had left over from painting my IRS. I used about 2 cutting discs during my entire build, but the single flap disc still has plenty of life left in it. The Dremel is great for small jobs but wouldn't recommend for this.
    Angle grinder with a cutting disc (or 3 ). By the way I call my angle grinder with a cutting disc "the death wheel" so hold on tight and be careful!
    Feb 2018
    Frisco, TX
    That's a good name for it. I removed the guard early in the build - I'm not sure how smart that is but I find it a lot easier to use without it. I only cut myself with it once!
    Top Notch Builder P100DHG's Avatar
    Pasadena, CA
    Is this a coyote thing mine sits directly in line with the frame rail. No issues but I’m using a 351W
    Jan 2019
    Richland, WA
    Must be a Coyote thing.
    Jan 2019
    Richland, WA
    Wow. Mine looks nothing like that. I have to trim off and remove three separate bolt holes.
    Quote Originally Posted by P100DHG View Post
    No, it's mainly a bell housing thing. The only available bell housing for a Coyote + T56 combination is a Quicktime RM-8080. It's S.F.I. certified and is a full circle where it attaches to the engine. The lower portion of the circle extends past the oil pan and the frame. Way too risky to leave like that. The Coupe frame in general is quite low already
  11. Thanks P100DHG thanked for this post
    Likes toadster liked this post
