Install this panel ASAP
Install this panel ASAP before installing various systems while you have easy access. I'm doing it now and it's a bare with the sway bar, master cylinder, brake lines, coolant pipes, shift cables, steering column, etc. all in the way because the rivets are inboard of the frame. The surrounding splash guard panels can wait because the rivets are outboard of the frame. inboard panel.jpg
Post Thanks / Like - 3 Thanks, 2 Likes
