I started this build quite a while ago, 9 years. Almost all of that time it has been in storage because of a career change. Didn't have the time or money. I have just recently started up building again and wanted to start some documenting and sharing.
My plan is to build a 427 street Cobra. That is- NO roll bar, NO side pipes, NO hood scoop with a FE. I really like the lines of the body and the sleeper look. Options will include heater, wipers, and full bumpers with other things that I can do to make it more original without going over the top. The MRKII also came with a Tri-States body, full hood and trunk with hidden hinges. This helps with the hood scoop because the hood scoop is separate so I just wont install that.
I started with a MRKII that was started by someone on this site. When I got the car the suspension front and rear was assembled including the IRS super coupe rear and axles. Prior owner started to change to a MP Brakes master with a full power booster by cutting out some of the braces. I didn't like the master so I fabbed in a Tilton dual master and hyd clutch hanging pedals. This and some changes to drop the trunk floor over the tank where the only things I did before storage.
Now I have started back up with more changes. My plan is to mock up as much as I can and do the modifications before I pull it back apart and powder coat the frame. I also started back up by spending the money for my TKO 600 from Mike Forte. This is behind a 428 PI. Bored .030 over with Edelbrock heads.
So far I have moved the parking brake to the top pass side of the tunnel. I made my own mounts and made a leaver that pulls the cables so the feel is better.
I also moved my firewall 5" forward and modified the foot boxes. Here is that thread from the other forum.
Firewall Forward
My biggest change so far that I am still trying to work out is the under car exhaust. The headers is the hardest part of that. With limited options for FE headers I was looking at custom headers but locally I have found that would cost $1500-$1800! I then tried some Sanderson Galaxie headers installed in reverse. The exhaust would then go under the foot boxes using oval pipe and mufflers from Spintech. The driver side works but the passenger side is right where the motor mount goes. I then tried to find someone that would be willing to modify the Sanderson passenger side or the FFR headers to make them work but without any luck with that I tried some Sanderson headers for a F100. They hug the block enough that they will dump the exhaust between the oil pan and the frame rails. So the headers work but create other issues. One is the 4" cross tube between the main rails. It has been done so I will probably notch the cross tube to allow frame clearance tubes. The other is that the headers interfere with the frame part of the motor mounts. Not a big deal that some welding won't fix. I will cut off the FFR mounts and weld in some street rod universal mounts. I think I have found what will work. I talked to Sanderson and they are going to make me another set of F100 headers with the collector tilted to the rear a few degrees so my pipes coming out will not have such a sharp turn as the collector ends about the top of the 4" main rails.
I included a picture of my car on delivery day with the body installed and one of the engine and trans just before the first of many installs. I know if there are no pictures it didn't happen! Should be able to do more updates now with more pictures of the future progress.
Thanks for reading the long post, Rod
