Page 12 of 25 FirstFirst ... 2101112131422 ... LastLast
Results 441 to 480 of 996
Thread: FFRSpec72 818R Build Seattle WA
  1. #441
    Kirkland, WA
    Pads are strictly race intended?
    Yes, they do make street pads but the XP series is for racing, I'm very happy with them on my Challenge car.
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
  2. #442
    Kirkland, WA
    Getting closer to completion , as with help of Frank818 and Mechie3 I was able to set my caster to +6 and camber is still a little low @ -1.8 so that is next. I had the car up to 90mph this weekend and all was stable, no tire rubbing issues. I'm still getting the air out of the cooling system (as I had a few leaks that I needed to fix). The car seems well planted.
    I need to install the rear fender well splash guards as I have a ton of crap that was thrown around. Also need to install the under the engine aluminum.
    Tony Nadalin
  3. #443
    Hey Tony,
    That +6 caster is going to give you a workout. I know Jim and John George are possibly looking at power steering.
    The -1.8 camber is a good starting point. I'm running -1.0F and -1.5R with a camber gain of 1* per inch of bump. It's working great with our Toyo R888.
    I've been running this season without the splash panels and no aero. No issues.
  4. #444
    Kirkland, WA
    Hey Tony,
    I run +9 caster on my challenge car so I know the issues, so that is why I only went to +6 with manual steering, I may have to back that down a little but I wanted to start high and see how much I can take. I'm running -2.5 camber in rear, would like to get the front to that point also but it's going to take some additional mods to do that.
    Tony Nadalin
  5. #445
    Kirkland, WA
    I also added my wide band 02 Sensor this weekend getting ready for a tune as I need to make sure I'm not running lean since this is a JDM engine tuned for more octane than the US market has.
    Tony Nadalin
  6. #446
    QC, Canada
    Nice to hear how well the spacers worked, I knew this was a cheap and easy fix to get decent camber-caster. They are more oriented towards caster than camber. They will give some camber but if you can go past 2.0 I'd be ****ing surprised. Caster at +6 is at the high end of what I could get with spacers. Black bushing pins not flipped.
    Have you considered cutting the A-arms' studs to get more camber?
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
  7. #447
    Kirkland, WA
    Frank thanks much for the help on the 10mm spacers for the LCA as it did give me enough caster and about .8 more of camber, I have been talking to Jim @ FFR and I think there is an easy fix on the camber also, so I will try that also. So I hope to wind up with -3 camber, +6 caster in the end.
    Tony Nadalin
  8. #448
    Bowling Green, KY
    Tony, You going to flip the rear LCA bushing? Really interested to find out what the gain is. I have been giving some though to doing it to see if I gain more adjustability on the upper arm.
  9. #449
    Kirkland, WA
    I added 10mm spacer there to get me the caster and a little more camber, looks like the easy way to get more camber is to slot the FFR spindle mounts so you can vary the tilt in on the spindle as right now there are just round bolt holes, make top one oblong so you can push the spindle in towards to ball joint and you will gain more camber
    Tony Nadalin
  10. #450
    Kirkland, WA
    Finished up the undercarriage as much as I can for now.
    WP_20160627_19_16_47_Pro.jpg WP_20160627_18_54_06_Pro.jpg WP_20160627_18_53_44_Pro.jpg
    Tony Nadalin
  11. #451
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Does that front splitter hang downward as shown in your pic, or is it just hanging down so you could easily install the sheet metal to the rear?
  12. #452
    Kirkland, WA
    There is a piece of aluminum that bridges from front splitter to under battery tray aluminum and that is at an angle so hard to see from the picture. So the front splitter is higher than the undercarriage
    Tony Nadalin
  13. #453
    Hindsight's Avatar
    Atlanta
    Ahh ok. I wonder if the resulting ramp from the splitter down to the undercarriage level causes any lift....
  14. #454
    Kirkland, WA
    There is not much difference (picture make it look like a lot) maybe a 1-2 inches difference, I don't expect much lift as with the splitter and canards I expect will negate any potential lift
    Tony Nadalin
  15. #455
    Tony, I don't understand why the deflector in front of the oil pan. Don't you want to keep the air flowing as fast as possible through the diffuser?
  16. #456
    Mechie3's Avatar
    Indianapolis
    My guess is that it reduces turbulence due to the oil pans shape and the opening around it for clearance.
    Zero Decibel Motorsports
    Check out my new website!
  17. #457
    Kirkland, WA
    yes, this the deflector, as I don't want to push the air up in the engine area with the hole in the aluminum for tbe oil pan, so this just smooths out the air to either side of the diffuser. My aluminum came from FFR when I got the diffuser
    Tony Nadalin
  18. #458
    Clovis, Ca
    Bob they sent you the wrong belly pan aluminum. It's supposed to go all the way back to the diffuser. They gave you the standard belly pan aluminum i'm guessing- for cars without rear diffuser. It took FFR 2 tries to send me the right part. the first one they sent was part of a Challenge car... lol
    Those deflectors are going to get eat up really quickly.
    Thanks- Chad
  19. #459
    Mechie3's Avatar
    Indianapolis
    Maybe I have the wrong part too. I couldn't figure out anywhere it was supposed to actually go. It wouldn't line up with anything.
  20. #460
    Clovis, Ca
    Old pictures of the correct belly pan-
    Thanks- Chad
  21. #461
    QC, Canada
    Tony (and some in Chad's pix above), what are those black fasteners for under carriage parts? Sidewalk bolts?
  22. #462
    Clovis, Ca
    https://www.amazon.com/Allstar-Perfo.../dp/B009Q73H8A
    Thanks- Chad
  23. #463
    Bowling Green, KY
    Tony, Have you had your maiden voyage?
  24. #464
    Edmonton, Alberta
    I didn't get that belly pan either, wonder if FFR will still provide it?
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
  25. #465
    Kirkland, WA
    Not yet as I was racing the challenge car with Karen Salvaggio last weekend here in the North West, this weekend it's raining and then I go on a business trips. I'm still doing minor stuff as I have been trying to install the rear wheel well liners and what a pain they are to get installed, I figure they will keep out some of the crap.
    How about you ?
    Tony Nadalin
  26. #466
    Kirkland, WA
    Call FFR as they should have it noted that it did not ship with your rear diffuser and they will send you a new one
    Tony Nadalin
  27. #467
    Bowling Green, KY
    How about you ?
    I am just finishing up the last few details, 3 weeks I will have it on track here (At least that is the plan) for another shake down then off to the dyno the end of the month. The plus side I haven't been in a rush so I can take my time on the details.
  28. #468
    QC, Canada
    About the belly pan, Courtnie is just sending me another one, most probably the right part this time. Many people didn't get the pan at all, some asked (like me) after, a couple of years after loll, and got the wrong, too small, part. Tnx to Tony for helping me identifying that part with his pix.
  29. #469
    southern NJ
    Tony, do you have any more pictures of the brake hose routing to the IC or how you are connecting it to the box around it?
    Brett
  30. #470
    Kirkland, WA
    Quote Originally Posted by Brett33 View Post
    Brett
    I don't have any yet as I have not completed the IC housing for the duct work, but the routing of the hose will be simple as the ducts point up and the hose will go from there to the sides of the IC
    Tony Nadalin
  31. #471
    Kirkland, WA
    I had some time to complete the rear wheel well aluminum, what a freaking pain, I did use Mechie3 mounts which helped but still a real pain. I also put the Carbotech XP8 (rear) and XP10 (front) pads on, good thing I did as when changing the rear I noticed that I had not torqued down the rear spindle nut on the axel, that would have been no fun ...
    WP_20160711_09_33_56_Pro.jpg WP_20160711_09_33_51_Pro.jpg WP_20160711_09_33_43_Pro.jpg WP_20160711_09_33_13_Pro.jpg
    Tony Nadalin
  32. #472
    Hindsight's Avatar
    Atlanta
    I've been dreading that part too. Any tips? Your install looks good and clean.
  33. #473
    Kirkland, WA
    Get Mechie3 mounts, as these make it easier. I had to enlarge the area next to the shock and the area short lateral link, best to have someone help as you will need 3+ hands to get the aluminum to bend to conform to the curve and rivet this to the tabs.
    Tony Nadalin
  34. #474
    Hindsight's Avatar
    Atlanta
    Thanks Tony
  35. #475
    Jun 2015
    Looks great! We wont be doing that....
    BTW, splitting compounds on the brake pads? I didn't think you did that on mid engine/high down force cars. Share please.
  36. #476
    QC, Canada
    I see you had to cut your inner splash guards, I know I will too to clear out the brake's line, but did you cut them to clear out some other parts like the upper link?
  37. #477
    Kirkland, WA
    Quote Originally Posted by RetroRacing View Post
    I have lots of years running on Carbotech pads, what I find is that a car that is weighted in the heavy in rear needs more aggressive pads in front to avoid the rear from locking up, I would far rather have the front lock than the rear, so I find this split of pad compound to be just about right, so I will see how this works out on the 818. The front and rear pads are the same surface area, the front pads are just thicker by a few millimeters.
    Tony Nadalin
  38. #478
    Kirkland, WA
    Just cut to clear the shock spring, upper link and brake line, not a total hack but a few inches had to come off.
    Tony Nadalin
  39. #479
    Feb 2014
    Ramona, CA
    Did you remove the rear spring and cycle the suspension with the tires on to see if it rubs your inner fenders? I'm guessing it will.
  40. #480
    Kirkland, WA
    Quote Originally Posted by matteo92065 View Post
    yes I ran the arm travel and it may ruub but I'm using 100lb stronger springs so I'm thinking it will not rub with these springs as I don't expect the travel to be as great as the stock springs
    Tony Nadalin
