0
Originally Posted by
Frank818
I wanted to know which build is the one you built like a boat? I think it's the blue.
Then what did you do to prevent water from dripping down from the windshield and into the sides at the front of the doors? There is a small triangle right on the sides of the windshield and underneath is the start of the cockpit. My water drops there and I was trying to find a solution to prevent water from dropping on the sides inside the frame, and as much as possible preventing it from dropping over the battery too.
The blue frame car has a marine compatible electrical system. red frame isn't built yet.
My car is a roadster, so I wasn't worried much about a few drops water in the cockpit.
I left all the slots around the edge of the floor to let any water out. My car has been outside during full blown thunder storms.
There is no issue with your 12v battery getting splashed.
