I did not use the FFR washers. the cables go to the shifter bracket and you adjust to the center of the throw. The cable that goes to the arm on the rear of the trans goes to left and right movement arm. The other to the fore and aft arm of the shifter. I did not bolt down the shifter till I had everything adjusted and shifting properly. Mine shifts so nice and quick. It was money well spent IMO. Sorry I did not take photos of the shifter attachment.
Thanks for the extra info... good to know the FFR washers are not needed. I get the gist of attaching the cables, it just seems like some washers should in where the cable attaches to the push pull levers under the shifter. I'm sure I'll figure it out when I get there. I'll be working on the back of the tranny first, so thanks for the extra info, guys!
That's what I like to hear! Can't wait to try it out.
Also, to consolidate info on the shifter in one thread, here's another post from Tom's thread
Has anyone installed the VCP shifter with the aluminum console that FFR is using now ? if so any problems ?
Tony Nadalin
2018 SOVREN Big Bore Champion
2012 ICSCC ITE Class Champion
818R Build in progress
OK, I can't seem to get the shifter to shift, I have tried adjusting the damn thing many different times and ways, it seems to move the shifting shaft in/out ok (3 positions) but not side to side. I'm hoping this is not a transmission issue ... Thoughts ???? Getting very frustrated
Tony Nadalin
Yes, but that was a while ago, I guess I can try that again, but I assume that the shaft all the way in is 1st/2nd and to the left is 1st, right is 2nd ? and 3rd/4th is in the middle and left is 3rd, right is 4th and all the way out is 5th and reverse, left is 5th, right is reverse ?
Tony Nadalin
