Thanks for the extra info... good to know the FFR washers are not needed. I get the gist of attaching the cables, it just seems like some washers should in where the cable attaches to the push pull levers under the shifter. I'm sure I'll figure it out when I get there. I'll be working on the back of the tranny first, so thanks for the extra info, guys!
wallace18
Mine shifts so nice and quick. It was money well spent IMO.
That's what I like to hear! Can't wait to try it out.
Also, to consolidate info on the shifter in one thread, here's another post from Tom's thread
wallace18
I have had some questions asked of me on the shifter brackets. Here is an answer I hope that helps. You cut the FFR bracket off at the end of the trans. The VCP shifter has the arm mounted up instead of down. You most likely will have to elongate the holes for the bolts to the trans on the side. Then install the VCP bracket for the other cable. I ran the cables under the intake to the shifter. Mount the cables to the trans first then locate your shifter. This worked well for me. Here is some photos. I hope this helps those who had questions.
Attachment 24397Attachment 24398Attachment 24399Attachment 24400
