Administrator
This is the question I posted earlier, and referenced above:
Ken, quick question for you. Are you aware of the difference between standard and pin drive width? I only ask because it will impact your wheel choices. Are you going with pin drive wheels? 15" or 17"? If you are going with pin drive wheels, check out Vintage wheels, a new vendor on the forum.
Good luck with the rest of your build, and keep up the good work.
PS looks like our builds are very much alike. And you're a web guy. We actually have a lot in common!
