I've been working on wiring. and working. and working.
My goal was to do something between what the FFR manual says and what iWire would do. Doing it this way should be easier for me and others to troubleshoot, as all the Subaru wire colors and names are unchanged. So far I am very pleased with the results.
The biggest change to the harness was to remove the two large fuse panels. Then replace them with one of these
fuse panels. Since most of what is on the original panels is no longer being used, I don't see the need of keeping them around and trying to place them.
I did keep the individual relays like B102, B103, B46, B47, B309 and the F27 relay block.
I'm down to 23 fuses/breakers, and 5 relays.
This is a picture of my panel with call outs.
This is shows more detail:
