Research Calibrator
Boog
Thanks!
I've been trying to figure out the 5x114.3 hub to 5spd plan and its good to know for sure that the key is in the trans stub shafts (and fully adjustable lateral links).
Correct, although there are two paths you could take:
(1) Do what I did and use the factory STI front shaft with the STI rear outer CV and STI front inner CV. To do this you need to have your 5-speed modified to be able to accept the stub input. I believe this in only possible if you replace the center diff with an LSD diff.
(2) You can have a custom axle made by the driveshaftshop guys that has the STI outer spline (to fit your rear outer STI CV) and the WRX front inner CV spline (to fit a pair of front inner CVs you buy).
In that second case you have the advantage that you can run any 5-speed, and you don't need to worry about pushing the wheels out because the axle shafts will be the perfect length.
