FS: Factory Five Racing 818S #67
SOLD IT! She gone! On her way to Oregon!
Update 8/27/2015: Price lowered to $24,000!
Update 8/6/2015: The car is now titled and registered in California under SB100. Forever exempt from emissions! Also, the new bumper has been installed.
No trades. Please have funding secured prior to contacting me. (If you're looking to finance, look into www.jjbest.com).
$24,000. Contact me directly at [email protected].
For sale is an absolute rocketship of a car. Putting down 341 hp and 390 lb/ft of torque TO THE WHEELS and weighing in at 2,000 lbs. Yes, two THOUSAND pounds. That's 5.86 pounds per HP. To give you a reference, that's more powerful than a C6 Z06 (6.2 lb/hp), Porsche 911 GT2 (6.1 lb/hp), Shelby GT350 (7.20 lb/hp), and the Challenger Hellcat (6.29 lb/hp).
PLUS, it can handle its own on a road course.
This is chassis #67. It was originally titled and registered in Arizona in March 2014 and I've been driving it around since. I have put roughly 3,000 miles on it since completion.
Below, I have provided a link to the build thread on the Factory Five Forums website, an excel spreadsheet showing the parts on the vehicle and their costs, and a link to Photobucket with some higher resolution pictures.
Build Thread Link:
http://thefactoryfiveforum.com/showt...romeS13-s-818S
Spreadsheet link:
https://docs.google.com/spreadsheets...it?usp=sharing
Loads of Pictures:
http://s157.photobucket.com/user/Jer...?sort=2&page=1
What it needs:
Fiberglass work to prep for paint/wrap/dip
Finish interior (painted, carpet, etc)
Or, you can leave it is and drive with a permanent smile on your face!
Parts list (I'm sure that I'm forgetting a couple of things):
Engine
LIC Motorsports B1 Short Block (2.5L)
B25 Heads ('06 WRX)
Supertech Valves / Springs / Titanium Retainers
LIC Motorsports Timing Belt Idlers
LIC Motorsports Air Pump Delete Kit
ARP Head Studs
Gates Timing Belt Kit
Grimmspeed Crank Pulley
Cosworth TGV Deletes
Moroso Oil Pickup
OEM '06 WRX Oil Pump
Tomei Turbo Inlet
Custom Extended Intake / Exhaust (Fathead Fabrication)
JDM VF37 Twin Scroll Turbo / Header / Uppipe
Boyd Welding Aluminum Fuel Tank
Cusco Engine Mounts
FrozenBoost Type 15 Air-to-Water Intercooler
FrozenBoost Type 100 Heat Exchanger
Jabsco 50840-0012 Intercooler Pump
Ron Davis Dual Pass Radiator
Perrin Fuel Rail Kit
TurboSmart FPR-1200 Fuel Pressure Regulator
Injector Dynamics 1000cc Injectors
Aeromotive 340 Fuel Pump
TurboSmart Vee Port Blowoff Valve
Cobb Accessport w/ Snail Performance Pro Tune (on e85)
NGK LFR7AIX Spark Plugs
ReplicaParts.com Alternator Mount Kit
ReplicaParts.com Brake/Clutch Master Cylinder Remove Reservoir Kit
Zero Decibel Motorsports Upper Coolant Reservoir Relocation Kit
Zero Decibel Motorsports Upper Radiator Brackets
Duracell Mini Battery (11 lbs)
Suspension/Drivetrain
VeryCoolParts Trailing Arms
Whiteline Rear Lateral Links
ARP Wheel Studs
VeryCoolParts K-Tuned Shifter
Cusco Transmission Mount
Rori's Shifter Rod Arm
Rori's Push/Pull Bracket
Brakes
OEM 4/2 Pot Brakes ('06 WRX)
Centric Premium Rotors (two sets)
Centric PosiQuiet Pads (Street)
Hawk Blue Pads (Track)
Stainless Braided Lines
ATE Type 200 Brake Fluid
Exterior
Enkei Kojin 17x8 +45 (10mm spacers) Front
Enkei Kojin 18x9.5 +45 (13mm spacers) Rear
Federal 595 RS-R 235/40/17 Front
Federal 595 RS-R 265/35/18 Rear
Interior
Sparco 353 Steering Wheel
Sparco Steering Wheel Hub
Sparco Ergo M Driver Seat
Sparco Evo II Passenger Seat
Rori's Steering Column Spacer
Sparco 6 Point Harnesses (Driver is HANS version)
K-Tuned Black Shift Knob
818S - #67 (SOLD IT!)
Delivered: 18 November 2013
Go Karted: 29 December 2013
Finished: NEVER!
Just a few questions that I’ve received and the applicable answers.
1. Q: How is your car as a daily driver?
A: As it currently sits, I wouldn't really label it "daily drivable"... That's actually one of the reasons that I'm wanting to sell it, so that I can get something that I can enjoy more often. However, my plan is that if I do keep it, I will be trying to make it more "daily drivable". Those plans would include adding carpet, reclining seats, regular 3-point seatbelt, etc.
2. Q: Your car is tuned to E85...can it still run on Cali 91 octane?
A: It currently has a VERY rough 91 ACN (AZ/CA/NV) tune that can be loaded with the Accessport. If you're planning on making that your primary fuel, you do need to have it tuned for it.
3. Q: Is the car only used as a track car? Any ideas about regular MPG street driving?
A: I have driven it mixed, but probably more on the street than the track. I've only done two track weekends with it and I've probably put around 1500 miles on it since completed (I can get the actual mileage if you'd like). The one time that I calculated my MPG was with e85 and it came out around 17 MPG.
4. Q: How comfortable is the car on the street? I had a Z4M roadster and I just sold my BRZ. Is the suspension too stiff for daily driving? The Z4M eventually was a little too rough for LA streets.
A: Aside from the noises, I thought it was pretty comfortable on the street. I actually bought and installed some stiffer springs because of a little rubbing while I was on the track. Of course the original springs are also included. I've never ridden in a Z4M, but I can only imagine that the suspension in the 818 would be a little rougher.
5. Q: How is the transmission? Is the 2nd notchy?
A: The transmission (shifter) feels a little weird to me, but I think that's because it's now using cables. I've always been gentle while shifting, as I've always heard horror stories about the 5 speed being made of "glass". Keep in mind, though, that mine has a 2012 WRX transmission and has the larger/beefier gears in it (same as the LGT gears).
6. Q: Do you know if AC is easy to install? I don't know how you drive it in Arizona summers.
A: While I don't think it would be THAT hard, I do not believe anyone has successfully done it yet. I know AZPete is trying to make it work on his, but I do not believe his is finished yet. I actually didn't drive it that much during the summer. It's not very comfortable and there's little airflow into the cabin.
7. Q: Is the pricing negotiable? I'm not interested in track seats and I know they are not cheap.
A: The price is somewhat negotiable, but not a lot of wiggle room. I'm sure you could easily sell the racing seats and seatbelts to a local NASA SOCAL racer, as they're all FIA rated and still current.
Finished: NEVER!
Finished: NEVER!
I am sorry to see you are selling the car after all the time and money that went into it. Best of luck with the sale.
Tamra
First start 12/21/14,
First "drive" 1/17/15
First autocross 3/29/15
Tamra
Thanks, Tamra.
Update: The car is on its way to the Sacramento area. I will be on my way there this weekend. (I'm moving there!)
Finished: NEVER!
Still for sale! The transmission is being replaced soon with a low mileage unit (~45k miles) from a 2006 WRX.
Oh, and I'm now in northern California, Suisun City to be exact!
Finished: NEVER!
Update 5/10/15: Price lowered!
Finished: NEVER!
Motivated to sell! Need this thing gone!
Finished: NEVER!
Finished: NEVER!
It appears that most people are hesitant based on the fact that it's registered in AZ. So, I'm beginning the process to register it in California today. Wish me luck!
Finished: NEVER!
Tamra
Car is now titled and registered in California! For sale again! Woohoo!
Finished: NEVER!
JeromeS13
Reduced to?
flynntuna
Reduced to?
That's a super old post. At the time, it was reduced from $27,500 to $26,000. How it's at $25,000.
Finished: NEVER!
Wow, for what you have in it, that's a bargain. I'm torn, I want to build my own... Yet you've done such a great job on your build. Got to give this some thought.
Still got it! Save yourself over $7k in parts and a year of your time!
Finished: NEVER!
Finished: NEVER!
Finished: NEVER!
Motivated to sell! Make me an offer!
Finished: NEVER!
Finished: NEVER!
Finished: NEVER!
Congrats! What's your plan now? Did you get the price you were hoping for?
Tamra
Tamra
Thanks! I did end up losing a good bit of money... But, that was expected. This is just such a small market... I've decided to stop with the project cars... My next purchase will be a 2012/2013 Audi S4. :-D
Finished: NEVER!
