stack
Does the car have a Mecanical or Electric Pump? If they used an electrical pump they may have also used the ford Enertia switch. You could have made it pop accidently and then the fuel pump would not run. Look for one of these in the trunk or under the dash and make sure the red button is all the way in.
+1 Inertia switch was my thought as well. I think I would start by finding the fuel pump, maybe disconnecting a line and see if it is pump fuel into a bucket. Check for voltage at the pump also. keep us posted.
