Results 1 to 13 of 13
Thread: Hose/fitting identification
    Kirkland, WA
    I'm trying to button up the engine and get a go cart soon and need some help finding a home for these hoses/fittings (circled in pictures), can anyone help identify and tell me where they go ?
    WP_20150217_19_38_57_Pro.jpg WP_20150217_19_40_47_Pro.jpg WP_20150217_19_42_04_Pro.jpg
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    The one off the wastegate solenoid goes to your boost controller, pretty sure
    Kirkland, WA
    OK, thanks, that's 1 down, so it goes here
    Tony Nadalin
    Leesburg, VA
    #1 goes to boost control solenoid
    Hope this helps with #2, looks like the smaller hoses run to the radiator, I'll do a little more digging about the larger one. (Edit: Bill clarified below)
    Someone post this in the past
    #3 also goes to boost control solenoid, photo from FSM Car Information section
    Frankfort, IL
    The one under the radiator cap goes to your overflow.
    The other small one next to it used to go to the top of the radiator. Look up wayne's degas mod for another option rather than running a line all the way to the front of the car.
    The 3rd (bigger) line on the coolant resevoir goes to the turbo (or somewhere back near the turbo - I can look when I get home if someone doesn't answer)
    Encinitas, CA
    Quote Originally Posted by billjr212 View Post
    I recently did 'Wayne's coolant mod'; if you do so, that hose goes to the top coolant pipe (tap a 1/8" NPT in the flat portion and put a elbow fitting to hose barb for it).
    Harley818's Avatar
    Vancouver BC
    Just to confirm that the answers above are correct.
    The hose from the cap goes to the coolant overflow
    The small hose next to it goes to the wayne coolant mod.
    The larger hose goes back to cool the turbo.
    the small vacuum hose goes to the boost controller.
    And the vacuum off the intake also goes to the other side of the boost controller
    Harley
    Bought 2002 Donor Jan 2014
    First Start Jan 18, 2015
    First Drive Feb 14, 2015
    Leesburg, VA
    That's my understanding
    Kirkland, WA
    Many thanks guys for all the info and help. I have the stuff to do the burp mod, the engine is in now and it's just a little hard to get to (I also have the rear engine to fuel cell firewall in place), so have to see if I can still do this.
    Tony Nadalin
    Encinitas, CA
    I was able to drill and tap the hole without removing anything. The turbo inlet, intake and coolant hose are the only things that are really in the way. If you've replaced the OEM inlet with a silicone one, it should flex enough to give access without removing it; mine did.
    Feb 2014
    Ramona, CA
    For the "wayne coolant mod" I installed braided clear tubing going to the expansion/reservoir tank. It was just what I had laying around. But it turned out to be a really good thing for me as I just got my car running and driving, now I can see bubbles coming up the line. You can see the self-burping process, and get a feel for when to add more coolant, and know when there is no more air in the system.
    Frankfort, IL
    Quote Originally Posted by matteo92065 View Post
    very cool idea. i like it. can you share where you got it, diameter, confirm it was pressure/heat rated? (wow, that was a lot of questions in a row)
    Feb 2014
    Ramona, CA
    Like I said, it was laying around...
    I looked up what it probably is: http://www.mcmaster.com/#51165K12
    Temperature is a little low, I'll probably replace it once I sort out everything. I don't regret having it on as its been informative up to this point.
