Thread: Another new one in AZ
    Tucson
    Guess it's about time I posted something...
    I've been lurking for years. Finally last July I pulled the trigger and ordered a MKIV kit, which was delivered in early October.
    So far I've got suspension, brakes, sheet metal, dash, fuel tank installed. Last weekend installed wheels & tires so it's officially a roller.
    Hopefully I'll drop the engine in Saturday so all the ancillaries can commence.
    Specifics:
    Base kit (with many options and additional parts ordered since)
    Tubular front lower control arms
    Manual rack & pinion
    Wilwood brakes
    Powder coated frame
    IRS - MK-VIII with added 3.55 gears, Auburn pro locker
    Ford Racing 427 crate engine with TKO-600 (thanks to Mike Forte; an example of an evolving plan as originally I was going to use a 302)
    Headers w/SS sidepipes
    - and various other things that escape my memory at present.
    Plan is for British Racing Green paint with brown leather upholstery and walnut veneer dash. And no hood scoop.
    AAZ in Tucson
    Congratulations! And welcome to the forum.
    I've upgraded you so you can set up your profile and create an album for pictures.
    Hi AAZ,
    Welcome to the forum. That sounds like a real monster you're building. Keep it between the ditches! I think my little 302 is trying to kill me. I can't imagine 500 hp in this car.
    Good luck,
    WEK.
    Maricopa AZ
    Sounds like a fun car. Enjoy the build.
    Senior Member gtaroger's Avatar
    Trenton Mi
    Welcome! Roger
    Tucson
    It's only 450 hp....
    AAZ
