The doors didn't seem too impacted by the alignment of the body since they have some adjustment options (so you can kind of fit the doors to where the rest of the body ends up). I would recommend setting up the front end first before doing the doors.
Tamra
First start 12/21/14,
First "drive" 1/17/15
First autocross 3/29/15
