10
25
Welcome home and glad to see you back at it. Can't believe they hadn't even returned the bellhousing yet and got your replacement. I would have been hot as well.
While you are looking at wire locations I had one extra pop up at the end you may want to think about. The wire for the GPS antenna for the speedo needs to go somewhere. Look in your gauge box. The GPS antenna is about 1 1/2" square and magnetic. I ended up placing it on the top of the PS windshield mounting location and running the wire through the hole in the 2nd picture of your last post. Not sure if that area would be visible with the flip top so just wanted to give you a heads up.
http://thefactoryfiveforum.com/showt...e-build-thread
