Results 1 to 13 of 13
Thread: trans dogbone
    Jul 2014
    Strathroy, Ontario Canada
    trans dogbone
    just out of curiosity I noticed after watching some videos of people driving there 818s the rear trans moves up alot when under load while driving I know people are going to the harder mounts but has any one thought of making mounts on the frame at the rear and securing the trans down with a hard dog bone mount that has a slight bit of play but stops it from moving as much as it does.
    I know the drag racing guys used to put a piece of chain on the frame to the front corner of the engine to prevent the engine from lifting under heavy loads when launching.
    thoughts?
    Senior Member metros's Avatar
    NoVA
    I know there has been at least 1 person to put a mount at the rear of the trans to stiffen it up. Can't recall who but they posted a picture.
    Mechie3's Avatar
    Indianapolis
    Matteo iirc.
    Zero Decibel Motorsports
    Check out my new website!
    Jul 2014
    I will look into it and see, it seems to make sence, the stock subaru had the upper dog bone from the firewall to the engine I am guessing that is what that was for on the WRX?
    Frankfort, IL
    Yup. Called a pitch stop on the WRX. The person that did it on here used something off of an Impala, I think
    Feb 2014
    Ramona, CA
    Yes, I put one in. I have recently put in stiffer mounts all around. The engine does want to move around, most noticeably in first gear around parking lot type driving.
    NoVA
    Wasn't there another builder who put one right at the tail end of the transmission?
    Jul 2014
    Just installed one on the tail end of the trans using an old sway bar end link, if it seems to work I will put something a little stronger. When I am ready I will video tape the engine trans with and without it.
    I have pics on my build blog.
    Freeport, ME
    Quote Originally Posted by metros View Post
    Erik T did IIRC
    Dan
    Aug 2013
    Santa Rosa CA
    818 rear mount 001.JPG This is what I did it is of of an early 2000s gm car. cost like 12 buck from orielys
    NoVA
    That was the picture I was thinking of. Thanks!
    Denver, CO
    Quote Originally Posted by D Clary View Post
    Any idea which GM?
    I used same one from an Impala.
